Thread: R410 or R22
    Feb 2013
    R410 or R22
    I have a First Co. Air handler and the coil was never used when it was installed. The installer used the original one. I am replacing my outside unit and would like
    to know if I can use R410a with the coil that was never hooked up. The original coil has a R22 sticker on it.
    Your contractor should have all the info needed.
    It may be compatible, but refrigerant type is not the only consideration.
    Mar 2013
    Joplin,Missouri
    If in doubt call a first pro distributor with a model and serial number and they should be able to tell you
