Results 1 to 13 of 14
    Dec 2008
    Buffalo NY
    Worked on my first ice machine today
    Had to help out another tech with one of his buildings since he was to busy. Call was for no ice in the kitchen. I said I have never worked on one but I can't break it anymore then it is. Get there and start trouble shooting. Found thisName:  ImageUploadedByTapatalk1367270352.960909.jpg
    Then found this gemName:  ImageUploadedByTapatalk1367270383.970747.jpg
Size:  55.8 KBName:  ImageUploadedByTapatalk1367270407.164357.jpg
    After I got the power back on the unit started working and went through its dump cycle. Then I switched it over and it started making ice. I did not realize how fast it makes it. Here is the model
    I got a new solenoid for it even though it was working. Seems to be making ice great now.
    Sent from my iPhone 4s
    using Tapatalk
    Join http://scopeny.org/ Shooter’s Committee on Political Education
    The world is full of sheep,try not to join the flock.
    Support the Skilled Trades, Don't DIY
    Aug 2012
    North Dakota
    1st one then whats your comon call to duty
    Dec 2008
    Buffalo NY
    Quote Originally Posted by mechanical'al View Post
    Commercial heating and cooling. RTUs, boilers, air handlers, condensers. That sort of stuff. Just never had to work on one before. Pretty easy after I looked at it.
    Sent from my iPad using Tapatalk HD
    Aug 2012
    North Dakota
    OMG thats kind of different there allways fun though and they are allmost allways in trouble due to a lack of cleaning and or general maintence cant say how many ive tinkered with
    Jul 2011
    Lehigh Valley, PA
    Quote Originally Posted by qwerty hvac View Post
    Was that at a pizza joint? I know that model. It's has a nickel plated copper evaporator. Good coin at the yard.
    Southeastern Pa
    Well.....did you clean it?????
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Oct 2011
    between here and over there
    Congrats you just open the door to send you to one every time there is one broken.
    Oct 2008
    Thankfully the majority of ice machine calls will be water management - often attributed to lack of cleaning. The problems due to refrigeration system problems are the true challenge. If you can get into some Manitowoc training, GET it!
    Dec 2008
    Buffalo NY
    Quote Originally Posted by timebuilder View Post
    No I just got it running it looked pretty clean. The guy who takes care of it is good with cleanings. But not good with solenoids. Lol
    Dec 2008
    Buffalo NY
    Quote Originally Posted by Capz View Post
    It was a kitchen in one of the data centers we maintain.
    So did the cover pull the wire nut off or you think it fell off by itself?
    Just wondering if that's all that was wrong.
    If the machine was off due to a safety cycling the power would have reset it and it would fire up again.
    FWIW The error code is stored and shows when you toggle power from off to on but will clear after so many good cycles.
    Dec 2008
    Buffalo NY
    Found it like that when the cover came off. Wire nut was on the bottom of the cabinet.
    Dec 2010
    Woodbridge Twp, NJ
    Holy crap, a B-series. Those things are antiques. Only certain parts are carried by my United, most are special order.
    Every customer you take for granted today will be someone else's tomorrow.
