    Dec 2011
    Hiram, Ohio
    the tech pressure tested my HP.
    He's doing my new install, brazed the lines, charged with nitrogen, found a leak where the txv connected to the suction line in the evap? Tightened that, then it held at 350psi overnight. Said all is good. But from what I've read here 410a can be much higher pressure on the liquid side.. should he have pressure tested higher? thanks, Mike
    Tallahassee, FL
    No that's plenty
    michigan
    Quote Originally Posted by SBKold View Post
    No that's plenty
    Agree with that. Thats all the higher I test at. Most dont test around here at all. I think its a necessity.
    I am the "Wally". All others are meer imitations of the original.
