    Atlanta GA area
    Harry Reid introduces bill to require background check to buy powder for reloading
    http://thehill.com/blogs/floor-actio...for-explosives
    And, the tangos didn't use smokeless powder. They used powder
    from torn down commercial fireworks, and maybe some black powder (either
    commercial or home made).
    Smokeless is a poor item to use, as once a container bursts, it either
    slows WAY down, or ceases burning altogether. Black and fireworks
    powder burns the same rate, containment or not.
    Smokeless only burns explosively contained under pressure, as in
    a cartridge ignited by initial heat and pressure from a primer.
    They are even talking taggants (again). Back in the 80s they were talked about
    and it was concluded they would impair/change the properties of smokeless
    in unpredictable ways - i.e., dangerous. Especially considering the
    infinite variations of taggants needed if they were able to trace a given
    pound of powder from mfr to end user. Currently taggants (or detectants)
    are used in plastic explosives as far as I know.
    GA-HVAC-Tech
    Oct 2002
    Florida Panhandle
    So when they have these civil war reenactments, what type of powder do they use, when I see them shooting I see white smoke.
    Seems it was the same white smoke in Boston. I know little about those type of guns, so I'm just asking.
    Roy
    A man is no less a slave because he is allowed to choose a new master once in a term of years.
    Lysander Spooner
    Apr 2009
    Quote Originally Posted by royc View Post
    Roy
    Yes, the civil war reinactments use black powder. Black powder is good stuff and is powerful enough to make a fair bomb. However, black powder is slow burning compared to modern powders.
    Ever wonder why old black powder muskets had such long, long barrels? That is because black powder is slow burning. As the powder burns thru the long barrel it is pushing the ball all along the barrel as the powder burns. Thus if you want more power you get a longer barrel so as to burn more powder behind the ball. With black powder, the longer the barrel the more power.
    If you put too much black powder in a black powder revolver all that happens is you end up burning the amount the short barrel can burn and the rest of the powder is wasted as it burns after it leaves the barrel and just creates a useless flame.
    No doubt though if someone makes a bomb from black powder it can kill a lot of people and do a great deal of damage. Modern powders would work much better for the purpose.
    Jan 2001
    Smokeless builds higher pressures faster....... making it more efficient as a projectile or explosive.
    The bible is my constitution and the constitution is my bible.
    WE THE PEOPLE refers to THEM and not YOU.
    Chewbacca Mom 2016
