Results 1 to 12 of 12
    Textbook bathroom exhaust install.
    This was not a DIY project gone bad, it was "professionally installed."
    I don't understand why no one cuts the sheet rock the right size for the fan. There seems to always be at least a 1/2-1" gap all tge way around on all of them and no one ever terminates them to the outside.
    Atlanta GA area
    Yeah... just does not make sense.
    All one has to do is hold the fan in place, trace around the outside with a pencil, cut with key-hole saw, and mount.
    Guess that is too hard for subs in a hurry...
    I will give them credit for one thing: They put the second brace in. Many I see are hanged on one side only.
    I really like the wiring also... just wait for the inspector.
    GA-HVAC-Tech
    Jan 2010
    So it's a 220volt fan also ?
    Jul 2009
    Could be a fan with a light...
    Jan 2010
    Good point....I would like to see his switch skills too.
    I'm not sure either of those pieces of wood it is sort of screwed to could legitimately be classified as a "brace!"
    Quote Originally Posted by stebs View Post
    Atlanta GA area
    I remember some where the 'hack' ( ) simply screwed two sections of wood to the sides of the fan... never mind attaching them to anything...kinda like 'struts' to hold it above the ceiling.
    GA-HVAC-Tech
    Jul 2010
    clay county missouri
    Ir good installs guy. I is pro
    Sent from my LGL35G using Tapatalk 2
    Central VA
    At least it's vented, that's already better then most here lol
    Sep 2012
    NW Louisiana
    I threw up in my mouth
    That is a hack job. I don't care if it was a Craigslist crackhead or a legit contractor.
    CT
    Some foil tape and some mastic fixed it right up.
    No picture though, if anything it looked worse, but at least it was air tight.
    I feel for the guy that has to replace it at some point though.
