Results 1 to 13 of 15
    Apr 2013
    Using Trane TAM7 air handler to circulate warm air
    I'm currently looking into a new AC and one salesman said something interesting. I have a natural gas burner pumping hot water through cast iron radiators. We find these radiators cause uneven heat within the room. One salesman said the TAM7 could be run all year and in the winter it would help draw and mix the air. Wondering what the professionals think about this? Can this air handler be used this way?
    Yes, and there is a hydronic heating coil option for it, so you could temper the air so it isn't moving unheated air around, and/or use it as the primary heat source in mild weather.
    Apr 2013
    I have no plan to add a heat coil....what about just running the air handler on "fan" with the regular heat going?
    Radiators are very large and all located under windows. This results in one side of the room bring warmer than the other. The basement which is finished and 1000sqft is the biggest issue. There is one large 10ft long radiator located in the opposite corner as the stairs. That area is warm and as you move closer to the stairs it gets colder. The basement is NOT air conditioned and it has no duct work. Wondering if I left the basement door open (there's an AC return located at the top of the stairs) would the air handler on fan draw air towards the stairs from the radiator and more evenly warm the basement?
    Quote Originally Posted by idmd View Post
    Probably not, since there is no supply to move the air.
    Your boiler water temp is probably set to high. or the boiler is over sized too much and heating the rads to quick.
    Is any of the duct work in the attic. if so, you don't want to use it in fan "on" mode in the winter. it could cause condensation in the ducts. If the duct work is all in conditioned space, then yes it will help a little. But may cause you to feel a cool draft.
    Apr 2013
    I just had a heat gain/loss done for the AC....the results said I need about 75k for heating and I have 110k. The boiler is only about 5 years old and in really good condition. The system also suffers from wild swings in temp. If you set the t-stat at 68F and the heat kicks on the room temps may go as high as 73-74F. I've always believed this was partly due to radiators that got too hot too quickly and the long period of latent heat provided by cast iron radiators.
    Are you saying I can partially mitigate my oversized boiler by just turning the water temp down--->radiators don't get as hot as quickly---->less "overshooting" desired temp?
    Yep. If the installers set the temp to more then 160, setting it lower will help a lot. Also, it could be your thermostat is causing the wide temp swings. What brand and model number is it.
    Apr 2013
    Oh t-stat is a cheap RiteTemp model 6022 from Home Depot.
    Might want a good thermostat.
    Apr 2013
    Any recommendations? AC and heat are on different T-stats.
    Honeywell 8000 series, or IAQ.
    Apr 2013
    Thank you!
    Saint Joseph, MI
    Keep in mind tha blwoing ari around hte house has soem advantages, but to move enough air to balance the temps, you'd use a fair amount of energy as well as defeat some fo hte point of having radiant heat.
    As mentoned, I think the temp is set too high. If the boiler is more than 25 year old, you might consider upgrading it to a condensing boiler wiht outdoor reset that can runn cooler water temps in mild weather.
    You might also consider a heat pump for mild weather (above 35-40F) and set-up the boiler/rads as the back-up heat.
    Apr 2013
    I'll have the temp checked. The radiators get hot enough to burn you after a few seconds. They are recessed under all the windows with not covering and no way to cover them. Is there any disadvantage to turning the water temp down to say 140 or 150F? I understand that the system may need run longer but I'd prefer a slower increase in temps. Also, I'm going to invest in a better t-stat.
    Thank you
