Results 1 to 13 of 22
Thread: Duct mastic
    Jun 2011
    SW Ohio
    Duct mastic
    What size gap can duct mastic be used up to? Can I use it on a gap about a 1/2"?
    If I can't use mastic what should be used to fill that gap, silicon?
    It's to seal off a return where the top has sagged down from the joist.
    Northeast Ohio
    I would try to push the duct back into place and fasten it first. If this is not possible, fill the gap with light gauge sheet metal then seal with mastic.
    DEM
    Jun 2011
    SW Ohio
    I will have to go get some light metal then because this is the top side of the return where it runs perpendicular to the joist so no way of pulling the top up.
    Oct 2010
    Mastic tape the cover with mastic or sheet metal and mastic.
    Jun 2011
    SW Ohio
    What about using that heavy metal foil tape (May be mastic tape?) with matic over that? I have some of that stuff when I built my attic box to block off my pull down stairs for insulating it.
    Oct 2010
    If its butyl backed foil tape it will work well (putty like about 1/16" thick) regular foil tape would be ok with a thick layer of mastic as long as you can get it to stick. Mastic tape (butyl backed foil tape) will adhere to just about anything.
    Jan 2006
    McQueeney, Texas
    It will need insulating afterwords of course, to prevent sweating or heat gain/loss.
    Jun 2011
    SW Ohio
    Quote Originally Posted by walterc View Post
    This is in a finished basement.
    This stuff: http://www.homedepot.com/p/Nashua-Ta...cked+foil+tape
    Oct 2010
    No, this stuff Removed link to direct purchase site.
    Oct 2010
    Sorry BT, hardcast 1402 is mastic tape.
    south louisiana
    that's my tape of choice 1402 mastic Hardcast brand!!
    the link is just foil with sticky backing...not mastic.
    you can use nylon webbing pushed into first layer
    of mastic & then mastic over it.
    but you should give it 24 hours to dry & recoat
    it with mastic.
    can you show us a picture?
    best of luck.
    Jun 2011
    SW Ohio
    Here are two pics where it has a larger gap.
    south louisiana
    that is the top of the return & a joist above it?
    why seal return to joist??
    it looks like return is independent of joist...
    and not a part of the return.
    am I just seeing this wrong??
