Results 1 to 13 of 15
    Apr 2013
    Burst or Split Copper Condensate Line
    I have a copper line running from a small condensate pump in a utility closet, up through the attic and out/down an exterior wall behind siding. The line was installed about 12 years ago, and shows no signs of impact or fatigue near the hole that I just discovered after using the AC only a few times this spring--see attached pictures.
    The hole appeared on the back (unexposed) side of the line about half-way between two spots where it was taped to the insulated refrigerant line. Is it possible that something *inside* the line caused this damage? The copper is flared out around the hole, so it seems unlikely to me that it happened from anything external... but it is in an area we use for storage.
    If this was somehow external damage, should the entire line be replaced, or could I get away with a cut-and-splice repair or even just solder and/or tape repair?
    Thanks,
    David
    Aug 2012
    Maybe that is why you have two lines because that one has already been replaced. Just a thought. Does your ac work?
    It's not if your doing it right it's whether your doing the right thing that is important.
    Apr 2013
    No, everything was new 12 years ago. The other uninsulated line runs the entire length with the insulated line from the interior evaporator out to the exterior AC unit. The condensate line just runs straight down the exterior wall to drain on a concrete pad beside the house. The AC has been working well... I noticed the problem when water stains appeared in the ceiling below.
    edmonds wa
    This is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise, commentary, or ask questions of the OP here.
    Further infractions may result in loss of posting privileges.
    Jan 2010
    Central Texas
    Since you didn't list where you live, I have to assume that you live in a Nothern Climate. So I would expect that the attic where this condensate drain line is run has gotten below freezing during the winter, allowing the water left in the line to freeze. That would cause the damage that you found.
    You would have to insulate the line once or have the line cleared/ blown out at the end of each cooling season.
    Quote Originally Posted by GuinnessX View Post
    Thanks,
    David
    When water freezes it will exert a pressure of 2000 lbs.psi
    Apr 2013
    I live in Arlington, VA. Yeah, freezing makes sense. It would be a big, expensive job to replace the entire line--especially since it has been covered by insulation and siding outside... Would a cut-and-splice repair work well for this line, or could that lead to problems down the road?
    Thanks,
    David
    May 2008
    Missouri
    This line need to slope towards the outside of the house, otherwise it'll simply hold water and freeze just as it did. Does the line slope towards the outside? A short piece of automotive heater hose and two clamps makes a simple fix.
    Mar 2013
    Joplin,Missouri
    Definitely freeze damage. You can. It and splice for the repair.
    Phoenix, Arizona
    Freeze damage, like someone said try to get the line to slope out to it's drain so it can't have water in the line next time.
    Mar 2009
    Mount Holly, NC
    actually, it's 9000psi...
    water will split mountains!
    that line needs to be wrapped with heat tape, as it's obviously freezing.
    The TRUE highest cost system is the system not installed properly...
    Find a HVAC-Talk Contractor by clicking here
    Do you go to a boat repairman with a sinking boat, and tell him to put in a bigger motor when he tells you to fix the holes?
    I am yourmrfixit
    buford, this is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise, commentary or ask questions of the OP here.
    Your post has been deleted.
    I don't like copper for the line off a condensate pump. I've found to many that were leaking and brittle from chemical reactions with stuff in the condensate.
