Page 6 of 6 FirstFirst 123456
Results 66 to 72 of 72
  1. #66
    Jul 2012
    North west Arkansas
    I have limited space available in my service van, and with tools, parts, and cylinders of refrigerant as well as reclaim cylinders there's not a lot of room,, I work on everything at these Subways,, so I carry tanks of CO2 already for beverage systems, and it's what I use to purge and pressure test,,, it's never caused me any issues, and I use a filter drier,,
    Haven't used it in anything larger than a 5 ton ac, so can't tell you about effects when used in very large systems,, for what I do, it's been fine..
  2. #67
    Feb 2015
    Waterdown, Ontario, Canada
    I have used both and I cannot tell a difference between the results.
    Some try the argument that CO2, in the presence of water, forms carbolic acid. This is true. Since we're evacuating the system to remove moisture, I don't see this as a major issue.
    Depending on the CO2 grade that you buy, it may or may not have a significant quantity of moisture in it.
    I like CO2 because there is a LOT more of it per can. I DON'T like it because that thing is HEAVY dragging it up to and across the roof.
    Hate to be a stickler for details, but CO2 plus moisture does not form carbolic acid. It forms carbonic acid, which is a weak acid.
    Nitrous
  3. #68
    In a boiler room
    Just when you think it's dead, it comes back to life!
  4. Likes Mike19 liked this post.
  5. #69
    Quote Originally Posted by Nitrous View Post
    Nitrous
    Appreciate the correction, Sir.
  6. #70
    Jul 2012
    According to the tree huggers co2 makes "global warming". Using that would be defamory to using 410A environmentally friendly gas lmao
  7. #71
    Quote Originally Posted by Capz View Post
    Show me documentation where it states it is okay to use co2 as a brazing purge gas.
    Do a search "co2 corrosion carbon steel".
    CO2 is not an inert gas.
    Maybe my terminology was a little strong. Unless somethings have changed, I read in one of my books never to introduce co2 into refrig systems. Having pulled high vacuums on the shells of many large cryogenic vessels, I can verify that it is much easier & faster to remove nitrogen with a vacuum pump than it is co2, air or any gas with a moisture content. Boiling off moisture is what delays busting below 500mi. I needed to get below 100mi on perlite tanks, and 10mi on super insulated mylar tanks.
    CO2 will also react to high heat such as it does in the GMAW.
    Read about it here.
    http://en.wikipedia.org/wiki/Gas_metal_arc_welding
    Guess CO2 rack systems are just all wrong...
  8. #72
    Yeah, I've seen that too...even on 40 year old stores.
    that can't still possibly be soot from not flowing.
    It's more likely burnt oil from high discharge temps.
    And no, I'm not joking. I've never flowed nitro during a service situation. you're talking about a handful of braze joints at best.
    IE: replacing a TXV, 3 joints, don't even wrap the valve with a rag...never had one fail....ever. Use a rose bud tip too, on full blast...for everything.
    Amen! Someone finally tells it like it is!
    No textbook fairies on this site in 2013!
Quality Home Comfort Awards
