Page 1 of 8 12345678 LastLast
Results 1 to 13 of 108
    Dec 2009
    Using CO2 as a purging gas instead of Nitrogen
    Does anyone use c02 to purge with while welding instead of nitrogen?
    Is nitrogen drier? or is c02?
    We have a tank of c02 for blowing out condensers and have always used c02. I have never really questioned what we should use but I want to be a better tech and part of that is using the right equipment.
    They use c02 as a refrigerant so it must be ok to use as a purging tool right??
    Let me know guys!
    thanks
    Quote Originally Posted by KickedGinger View Post
    Let me know guys!
    thanks
    I have used both and I cannot tell a difference between the results.
    Some try the argument that CO2, in the presence of water, forms carbolic acid. This is true. Since we're evacuating the system to remove moisture, I don't see this as a major issue.
    Depending on the CO2 grade that you buy, it may or may not have a significant quantity of moisture in it.
    I like CO2 because there is a LOT more of it per can. I DON'T like it because that thing is HEAVY dragging it up to and across the roof.
    Jul 2011
    Lehigh Valley, PA
    But it is ok to drink it but you wouldn't if you knew what is in it or should say what use to be in it prior to the soda bottlers pushing for higher purity beverage grade co2. I was in the ind gas business for 27 years. I can't count the amount of times I had to dump large co2 tanks full of product due to high levels of a poison gas. (The name escapes me, I been away from this stuff for six yrs). This gas would rise to the top of the tank and would not liquify but never the less, if a sample from the tank after a 20 ton delivery came back positive, we would be called out to dump it. Funny thing is, Coke never shut down. They kept filling soda. But keep in mind, product withdrawal was from the liquid side or bottom of the tank and the -5F liquid is vaporized with steam or electric heaters.
    Feb 2015
    Waterdown, Ontario, Canada
    Hate to be a stickler for details, but CO2 plus moisture does not form carbolic acid. It forms carbonic acid, which is a weak acid.
    Nitrous
    Quote Originally Posted by Nitrous View Post
    Nitrous
    Appreciate the correction, Sir.
    Jul 2015
    Uniweld does not recommend that CO2 be used for purging or pressure testing an A/C&R system because it may form carbonic acid within the system, causing premature equipment failure. However, there are certain applications where CO2 has its advantages. Because CO2 starts out as a liquid, it has a tremendous expansion rate; it is an ideal source of portable gas Pressure.
    CO2 is ideal for clearing a condensate drain line, cleaning coils, inflating tires, unclogging a sink, operating impact tools and much more.
    Norm in Arkansas
    Quote Originally Posted by greenbomb View Post
    Norm in Arkansas
    Got documentation to support that?
    I've seen documentation which does support using CO2 as a purge gas in an AC&R system.
  8. Likes greenbomb liked this post
  9. #8
    Jul 2011
    Lehigh Valley, PA
    CO2 is a corrosive gas and should not be used.
  10. #9
    Dec 2009
    Quote Originally Posted by Capz View Post
    Can you back this up with evidence?
    It cant be that bad if there is a big push for c02 as a refrigerant.
  11. #10
    Jul 2011
    Lehigh Valley, PA
    I'm not a scientist or a metallurgist, I cannot back it up. I do know co2 cylinders are required to be retested every 5 years rather than 10 yrs as for nitrogen, argon because it is considered corrosive. I was taught not to use co2 in refrigeration systems. I'm old school, try and do things correctly & safely. If co2 is okay to use why hasn't it been accepted for the last 30 years as a purge gas? I never read one time anywhere where is can be substituted for nitrogen. Have you? But I do know co2 is much heavier than nitrogen. I'd never for anything but blow out dusty condensers. Would really suck as a leak tester in a pressurized system, too dense.
  13. #12
    Dec 2009
    Sounds like C02 as a purging/pressure test tool gets a failing grade.
    Maybe I should make the switch.
    I just purchased a new micron gauge and 1/2 evacuation manifold with 1/2 hoses!! (in the mail)
    Cant wait!
  14. #13
    Calgary, Alberta
    CO2 is considered an inert gas under normal conditions.
    It is used for MIG welding but it can make steel more brittle due to the CO2 reacting to the high temps.
    I'd be reticent to use it as a shielding/purging gas for brazing copper without proof it won't react with the joint in the long term
