Results 1 to 12 of 12
    Apr 2013
    Confused w/ what size 2 ton or 2.5 ton
    Here's the story, my current system is a 2.5 ton AH w/ 3.5 HP and its on its last legs so looking to get it replaced.
    So far i have I have been told to get a 2 ton HP and AH but the other guy says 2.5 ton is better. I currently live in a small townhome which is 1200 sqft but has a basement not including the sqft. I reside in MD so temps can get about 15 degrees at lowest to 90 degrees avg in summer. The system I'm looking at getting is a 2 stage HP w/ variable speeds AH. Dunno if that makes the difference in size. They both are quoted in about same price rance as one is a Bryant Evolution and other is Trane (don't recall which model thou.)
    Dec 2010
    A H/P is generally oversized for the heating side of the operation. 2 tons of cooling is more than enough for your town home. With lows of only 15 degrees, I guess I would recommend the 2 ton H/P for better second floor (cooling) comfort.
    That said, the Bryant guy has a computer program that will run the operating comparison costs between the 2 ton and the 2.5 ton. With the smaller 2 ton unit, during the winter, you'll be running on resistance heat ($$$$) more often, but it'll cost less (and better comfort) to A/C during the summer. It could be a small trade off. Let him show you the difference.
    North Dakota
    depending on availability and prices of nat. gas in your lacal. you may come out better going w/ a forced air furnace instead of the airhandler and it could be a better match to the manual j load calcs. that weren't mentioned
    Saint Joseph, MI
    In your climate, It's still fairly humid in summer. I'd lean towards the 2 ton and be careful not to use any setbacks on the coldest. The evolution is very, very nice. Very quiet, low warm airflows when heating and excellent humidity control. If you can afford it, consider the Evolution Extreme heat pump. It won't need heat strips hardly at all even at 15F.
    I have 2 Carrier Infinity systems in my home, absolutely love them. Even our local commerical Trane area sales/service rep admits that on the residential side, its' still probably the best overall system out there. Trane makes very nice units as well. IF you have enough ductwork, you could consider a 3 tons XL20i. DO NOT however oversize a XL16i... EVER! Poor latent capacity (humidity removal) on low stage when oversized at all. Also the heating capacity on the XL16i is pretty low too. A 2.5 Ton XL15i would be a better choice IMO if you can;t afford the XL20i. With the Evolution extreme, you'd want a 3 ton unit as well.
    Apr 2013
    I was able to contact the Byrant sales rep and he actually showed me calculation for the size is recommended. Shows cooling is 1.7 ton and heating is 19,200 btus which means 2 ton is recommended.
    On the other hand the Trane sales rep didn't even use a calc and just said on his experience for my size of town home should be 2.5 ton HP w/ 3 ton air handler.
    So, im at lost really.
    As of the equipment break down..
    Trane - TRANE XB 13 2.5 ton HP w/ XB Airhandler 3 ton Multispeed motor comes w/ a emergency heater strip.
    Bryant - Model 286B Evolution system 2 ton HP w/ 2 ton Model FE Airhandler. But I don't see anything that says it has an emergency heat strip? (can someone clear on this)
    The prices on these 2 are different in a long shot. So which is a better choice?
    Jun 2005
    SW Wisconsin
    Did the guy who did the calc., show you what some cost-effective retro-work would do for lowering both heat & cool loads?
    Could possibly do a few cost effective things to make the 2-Ton the better choice; which will improve airflow & overall efficiencies.
    AOP Forum Rules:
    Rules for Posting
    Rules For Equipment Owners
    Equipment Owners Find a Contractor HERE!
    Free online whole house load calculator & Sizing: http://www.loadcalc.net/ Anyone can use it...!
    udarrell
    Apr 2013
    Yea he mentioned will add "arc fins" on top of the air handler that pushes out the air to other vents. Also will expand a larger duct from AH to other ducts.
    )))(((( <--- arc fins (pushes air to left and right instead straight to top
    | | <----- air blower
    SW FL
    Quote Originally Posted by mickeykool View Post
    You are not the one who is confused,
    TRANE representative is acting Old School and Very Lazy. DO NOT WASTE ANY MORE TIME WITH THIS TRANE FELLOW.
    Two 3 kW heat strips would be required for EMERGENCY Heat ( without a N.G. furnace).
    Designer Dan
    Apr 2013
    I should also mention I have no gas line to my house. So everything is electric.
    SW FL
    BRYANT model 225B may have a little better HSPF rating.
    You probably only have 300 hours per year at less than 20'F in MD.
    Similar,
    Carrier 25HCC530A30 Outdoor Section With FX4DNF031 Indoor Section
    provides 16,550 Total BTU/HR with 1.81 kW at 17'F
    Designer Dan
    North Dakota
    yes Dan is on point dont catch that trane
    Apr 2013
    Thanks for all your responses, I ended up going w/ Brant system. Hopefully this is a good choice for me.
