Results 1 to 13 of 13
Thread: hoshizaki
    Apr 2013
    hoshizaki
    I need help. I am working on a km-1600MRE3.
    Aug 2009
    Maine
    A bit more info would help
    NH
    Sounds like a bad float.
    Jul 2012
    Western KY
    Could be the water inlet valve.
    Apr 2013
    Ok the system has been down for quite some time. I replaced the board and the float. Cranked the system up and it is making ice but the cubes are small. It seems there is too much water after the harvest.
    Oct 2011
    Chicagoland Area
    Small ice cubes? Use smaller cups
    Newnan Ga,
    Quote Originally Posted by offroadman75 View Post
    what was the problem?
    Newnan Ga,
    The most common problems for older hoshi's are plastic teeth in water pump out valve (3 screws triangle) left of float. Float switch full of debris. Water dist tubes dirty. condenser dirty.water fill solinoid,
    Oct 2008
    Quote Originally Posted by Grayline View Post
    Ditto. Probably got holes in the grate below the evap plate. That's the "teeth" mentioned that broke off the grate. If so, replace the grate with a new one once you're done.
    Anyway, for now - remove that grate and check for anything in the reservoir that can get sucked up by the pump. Drain the reservoir.
    Remove the check valve (that triangle with 3 screws), then clean it. Also clean the float switch. Reassemble.
    All will be good then. Make some ice.
    Oct 2008
    ...the cubes are small. It seems there is too much water after the harvest.
    Did you mean "too much water at the beginning of harvest?" Water refills DURING harvest, so reservoir SHOULD be full at the end of harvest cycle.
    Make sure the float switch is properly positioned, which usually as low as it will go. The float switch determines the cube size.
    Jun 2012
    Tenn
    Are you watching the harvest cycle? Is the water being pumped across the evaporator plates? Have you watched enough of these ice machines to know if you see enough volume being pumped or the pump shuting off to early? As has been mentioned, sort of, the pump not throwing enough water up across the plates is noticeibly more common.
    Phoenix, Arizona
    There could be several issues happening.. like, low charge, plates seperated, water slowly draining passed dump valve, water float set too low. Are there any cubes a good size?
