Results 14 to 17 of 17
    Aug 2011
    Does the drive itself accept your fieldbus? Lon? Which can tell you the speed?
    Greater Seattle Area
    Do the VFD's have a Lonworks interface option card installed or available? A lot have this option now and perhaps that would be a simpler solution since you get a multitude of data out of it to utilize for speed (Hz, Amps, Ref Hz as seen by drive etc.)
    Apr 2006
    Columbus, Ohio
    Quote Originally Posted by controlgeek View Post
    That is a good thought. I believe they are Danfoss VFDs. I will look into that as a option. That would be a lot more accurate.
    Thanks for all of the replies.
    J. King
    Sample and hold. I've used it for years for static pressure sequences and it works pretty solid.
