Results 1 to 13 of 15
    Apr 2013
    Noisy Aaon Rooftop Burners
    I have a 26 ton Aaon rooftop unit that is 3 years old and has since installation made excessive burner noise when the burners initially come on. The burners come on full for the initial 45 second start up and then modulate down. Nothing has been modified on the unit, the gas pressure, orifices, alignment and blowers are all checked out. The unit sounds like a jet engine on the roof. Aaon says its normal.
    Any help would be appreciated.
    Oct 2011
    Chicagoland Area
    2sac says it's normal as well
    May 2009
    South of Heaven
    And if you ever find a failed inducer motor on these get a new fan wheel with the motor.
    Apr 2013
    That would be OK if below the units was a warehouse but its classrooms and they refuse to use the space due to the jet engine noise.
    Has anyone had experience in replacing the burners with quieter ones?
    Apr 2012
    Louisiana
    I doubt replacing the burners is the way to go. Maybe some changes to the duct work? Where is the sound entering the space?
    Oct 2010
    Use some flex with a couple 90 degree bends to absorb the sound if possible. Is the gas pressure too high, I've seen some that light with too much pressure and sound like a jet engine.
    Pa
    This is normal, is it a drop ceiling? If so install batts of insulation
    Mar 2011
    Louisiana
    This is not an equipment issue as much as it is a building design issue. Architects are using lighter and lighter construction and HVAC designers, in many cases are, not able to place units away from these sensitive areas. This leads to the end result to be exactly what you are complaining about. If it is not burners, then it is compressors or fans, does not matter which brand of equipment is on the roof. To kill sound transmission the structure has to have mass. Unfortunately the perception is that Acoustical treatment costs too much until the owner has a space or building that is uncomfortable or unusable.
    J
    Apr 2013
    Quote Originally Posted by jtrammel View Post
    The gas pressure is right at spec.
    thanks
    Apr 2013
    Thanks for the reply.
    Yes, it is a drop ceiling, have you tried to spray foam the botton of the roof decking instead of the batt insulation?
    Apr 2013
    You maybe right but something needs to be done the space below the unit is unusable. They have a 90 deg duct attenuator to help cancel out the noise but dosen't look like it works too well. Your thinking that the noise is not coming through the ducts but transmitted through the metal roof decking.
    Salem, WI US
    I had some issues with noisey condenser that sat on sleepers that we installed heavy duty vibration springs under the unit to lessen the sound issues. I am not sure if the AAon RTU Curb has options that may include some sort of sound elimination design.
    Betabass
    Success is to be measured not so much by the position that one has reached in life as by the obstacles which he has overcome.
    Mar 2011
    Louisiana
    Quote Originally Posted by ktr52 View Post
    That is what I am thinking. The solutions while a pain in the a$$ may get you a usable space. Lift the unit off the curb and put 2 layers of 5/8" gypsum board wall to wall in the curb with a coating of the Green Glue product in between. Be sure to lap the joints and seal the edges. You do not want a pathway for noise. Secondly add a similar solution underneath the roof deck and add some 6" batts on the top of the gyp panels for sound absorption. Make this as large as possible under the unit hopefully 3 - 5' beyond the unit's footprint. I know easier said than done.
