+ Reply to Thread
Results 1 to 7 of 7
Thread: Using the AHRI Directory
    May 2009
    Earth
    Confused Using the AHRI Directory
    Every time I try to use that thing I can never get results. Does any one have any pointers?
    I am looking for the following Daikin matches
    Cond Evap
    RXS09LVJU FTXS09LVJU
    RXS12LVJU FTXS12LVJU
    RXS24LVJU FTXS24LVJU
    If someone could look these up and tell me what fields you selected that would be great and moocho appreciated!
    Quote Originally Posted by EugeneTheJeep View Post
    Cond Evap
    You need to put in as little info as possible.
    For the first one, I just put in "RXS09" in the field for "outdoor unit model number", then hit the search key.
    May 2009
    Earth
    Thanks Alot! Your the best, I thought I had this figured out last year, but must have forgot after cooling season?
    Thanks again!
    May 2009
    Earth
    I was going to ask how you got the certificate, I had to double click. I also found out I was selecting air source heat pumps, instead of variable speed mini split ductless heat pumps.
    Glad you got it figured out.
    May 2009
    Earth
    Yeah, I just posted that, because next time I forget I have this thread bookmarked for easy refresher.
    Now our utility wants us to do the forms on line, once you hit submit for a particular system, you can not turn back and edit if you make a mistake.
    May 2009
    Earth
    And thanks 3x, I put together a match for a highly educated customer and I am sure it will help me get my foot in the door.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
