Results 1 to 13 of 14
Thread: Line set
    Apr 2013
    Line set
    Will a 3 ton unit work w/a 5/8" line set? If so what are ramifications, compressor damage, lower eff, etc?
    Southold, NY
    5/8 liquid line seems a little large.
    Mount Airy, MD
    Thread relocated to AOP
    Mar 2013
    Joplin,Missouri
    I assume you are talking about a ⅝ suction line. That would be undersized for a 3 ton application. You would want to use a 3/4" suction line and a 3/8 liquid line.
    Apr 2013
    I know 3/4" is spec, but existing in wall is 5/8 can't replace so will 5/8 damage 3 t unit or will it even work. Another option is I have a redundant 5/8 line is it possible to combine these or would that be to much capacity?
    Mar 2013
    Joplin,Missouri
    I would not want to comment if the 5/8 would work or not. It may function, it may not but it would not have near the proper capacity I don't like to give advice to people when I'm not positive what the outcome would be.sorry I would just open the wall and change the lines and make it right
    As long as it is not a really long line set, a 5/8" suction line is just fine with a 3 ton R-410A system, but there will be capacity loss.
    How lone of a run is it?
    Apr 2013
    25' to 30'. So all I will loose is a small % of eff? A 5/8-1/4" line set won't harm unit?
    Apr 2013
    Sorry about that line set is 5/8-3/8"
    Quote Originally Posted by Tim sample View Post
    Assuming a few LR 90º fittings, your looking at loosing in the neighborhood of 500 btuh of the systems capacity, vs around 150 btuh loss with a 3/4 inch suction line, so around 350 btuh difference.
    If the line is in good shape, its not worth chasing that 1% difference in total capacity, as you would likely never see a payback in the life span of the system.
    The higher refrigerant velocity in the 5/8" suction line will result in more reliable oil return, so could potentially actually extend the life of the compressor.
    You didn't mention the 1/4" liquid line in the OP. That is a no go for a 3 ton system, even with a short line set, due to the pressure drop.
    5/16 would be the minimum.
    Aug 2010
    West Monroe, LA
    I would say more then lickly if you have 5/8 suction line then your liquied line will be 5/16 which might appear to be 3/8 really hard to tell then apart sometimes. Will it work yes but expect btu loss.
    I would confern that you do have 5/8 and 3/8 and get installer to see what the loss will be and if you have 5/8 and 5/16 same applys you are pushing the limits of the line set. If its 1/4 on the liquid line then it will not work propely and all kind of problems can occur.
    Installer needs to run this through pipeing software and see what the loss is or will be. Only real way to know for sure.
    Apr 2013
    Thank u guys for the info,I'm going for it. Don't want expense and mess of 3 floors of Sheetrock tear out and replacement to change line set. It is 5/8-3/8"
    It is 5/8-3/8"
    Then you are good to go.
