Hartford Duracool - door frame heater replacement procedure?
Results 1 to 7 of 7
    Hartford Duracool - OW355-2 (or something like that <g>)
    How does the Duracool door frame come apart to replace the heater wire?
    Does that stainless strip for the gasket seal-surface come off first?
    How exactly to I get the plastic jam away from the wall panel?
    And I mean in such a way that I can re-install it later. <g>
    PHM
    Southern,Ca
    All the duracool heaters I've replaced have been just the standard heater cover. Do you have any pictures?
    What is "the standard heater cover" ? <g>
    And how do you get it off / open?
    No pics yet - I meant to take my ipad but cleverly forgot to.
    PHM
    Quote Originally Posted by crstephens83 View Post
    PHM
    Central WA
    Outer channel snaps over inner channel. Gently pry up one side with a screwdriver and you can walk it off.
    This is what I consider "standard." I haven't worked on your specific brand...
    Southern,Ca
    Quote Originally Posted by cjpwalker View Post
    Right on the money that is what I consider standard also. I use a metal putty knife to gently pry one end loose from top to bottom. Be very careful though the metal bends really easy. I than use metal tape to hold the heater down and carefully clip the cover back on. I use a plastic dead blow hammer and gently tap the track back on. Usually a heater replacement takes me about two to three hours
    I wonder if we are all talking about the same thing? This is a flush door and frame panel in the side of a walk-in freezer. There isn't anything which looks like that snap-together arrangement pictured a post or two ago. Is that used on a surface mount door assembly? Or a reach-in door maybe?
    PHM
    Southern,Ca
    take some pictures todaybecause what we are talking about is standard on most walk in freezer doors its just a metal track that the gasket sits on
Comfortech Show Promo Image
Plumbing Talks | Contractor Magazine
Forums | Electrical Construction & Maintenance (EC&M) Magazine
Comfortech365 Virtual Event
