Page 3 of 5 FirstFirst 12345 LastLast
Results 27 to 39 of 61
  1. #27
    Quote Originally Posted by R123 View Post
    ...I would concentrate on checking that the EXV is working properly and checking the sat evap and compressor suction temp sensors.
    that is what ryan was saying and i was backing him up. no temperatures or pressures or amps or volts or the Moons position in the Heavens have been confirmed with an accurate or separate meter/gage/telescope.
  2. #28
    Apr 2012
    Louisiana
    What temps are being displayed for saturated evap and compressor suction? Simply checking the ohms is not enough you need to read the voltage across the sensors also. That's all I'll say in the open forum.
    You really should sign up for a pro account you've got more than enough post.
    And I'm about 99% sure low charge is wrong.
  3. #29
    up in the hizzy
    Quote Originally Posted by Sicofthis View Post
    Well, my friend, you were 1% right!
    Pulled the charge today and the chiller was 48LB short, fixed the leaks and left it pressurized with 200psi of nitro overnight.
  4. #30
    Mar 2011
    Long Beach, CA
    Now you can begin to troubleshoot.
    But I am still learning and looking for a new mentor.
    _______________________
    In a strict sense troubleshooting is not part of the repair..........understand the symptoms and you will find a solution.
  5. #31
    Apr 2012
    Louisiana
    Lol I'll take 1%, good job on calling it. Never seen low charge trip that fast, though sounds like you were super low.
    You said small leak earlier, was there much oil?
  6. #32
    up in the hizzy
    There was not a lot of oil, that puzzled me, the oil separator most be doing a hell of a job.
    last week I locked circuit 2 and circuit 1 was running fine when I left, got there this morning and circuit 1 was in alarm, something to do with the starter, re-setted it and didnt trip again. Customer told me they had nothing but problems with the RTAA, way to go Trane
  7. #33
    Mar 2011
    Long Beach, CA
    What type of starter do you have. Is it a closed transition starter?
    How many hours does the control display.
  8. #34
    up in the hizzy
    Quote Originally Posted by alcomech View Post
    Yes! it is a closed transition y-delta starter, dont remember the exact hours.
  9. #35
    Mar 2011
    Long Beach, CA
    If you are having starting alarms such as failure to transition, you should check auxiliary contacts.
    You can try to ohm them out, and if over 10 ohms this is an indication that they are failing. But if they are original or have over 15,000 hrs on them just replace them.
  10. #36
    up in the hizzy
    Its all original and cuttler-hammer discontinued it, I going to try matching them to something. Thanks for the info.
  11. #37
    Mar 2011
    Long Beach, CA
    What do you mean? The parts are OEM and as far as I know they are still available.
  12. #38
    The Hot South
    X2
  13. #39
    up in the hizzy
    I tried to buy it direct from C-H and was told they were discontinued, I like to circumvent Trane cause they charge an arm and a leg for every little dingy thing.
