Results 14 to 26 of 60
    May 2011
    Western, KY
    To shorten the line set if I'm understanding properly.
    Sounds inefficient but I guess everybody has their way.
    Usually the only joints I have are at the units and I don't get the torches out at all. Did have a church recently where the lines ran over 50' so we had two braze connections on the rough in, I leave enough sticking out that I can cut, flare and connect with no more brazing. Also, if the joint is accessible you can always use a flare coupling for longer lines when splicing.
    I've seen some rough factory flares, so I typically cut them off and do my own.
    May 2009
    South of Heaven
    I've had problems with the YJ tool on 1/4 inch od tubing. It is difficult to get to clamp tight enough and the flaring action pushes the pipe from the dies. Other than that it seems to do fine.
    Delaware
    Tighten the side closest to the copper first.
    Quote Originally Posted by danielworkerbee View Post
    Our guys use the factory flare on the line set and just cut & braze a foot up from the flare.
    luck dan
    On all of the factory made line sets I've seen, the factory flares are garbage compared to the nice crisp burnished flares my YJ flaring tool makes.
    Usually they are bad enough that they would fail if I checked them with my Daikin flare gauge.
    May 2011
    Western, KY
    You have any links to this flare gauge and it's implementation?
    Nov 2012
    Toronto
    Ive had the YellowJacket deluxe for a couple years and I have had great results with it. I don't flare a whole lot but I cant lose a part if its all one piece! And you don't have to guess the protrusion.
    Apr 2013
    Knoxville TN
    I was taught years ago by a old tech to use a nickle (thickness) to measure the pipe in the clamp. I hope im explaining it right, but i always do it and never had any problems. I can take pics if needed. I guess that would be consider a flare gauge. I have told this to other techs in the field and they never heard anyone do that but they all agreed its a good idea.
    Apr 2012
    winnipeg
    I make flares everyday..... how can this old man never have trouble..... use imperial eastman
    Athens, Ohio
    Thanks for all the replies. We already make plenty of flares with no problems with the older Ridgid tool. Deburring, proper flaring technique and use of a torque wrench are already standard procedure for us. We are Mitsubishi Diamond contractors so we are following their training (we used this procedure even before the training.)
    I just don't know why the old tool produces a a good flare but neither of the new ones does.
    Oct 2010
    Quote Originally Posted by phase24 View Post
    That's what I was taught too. One of the guys at our shop does the cut factory flare and solder it on trick because he says he doesn't trust flares. It's like an act of congress to convince him that you can make a good flare with a flaring tool.
    Quote Originally Posted by jtrammel View Post
    Hopefully he is kept far far away from mini split and VRV equipment installs...
    Oct 2010
    As much as possible, he's used more for manhandling and sledgehammer work rather than precise or technical stuff.
    Quote Originally Posted by carmon View Post
