Results 1 to 7 of 7
    Apr 2012
    Service tech said he pulls great vac on his systems
    We always wondered why he pulls downs so quick! Guess we know now.
    Feb 2011
    Georgia
    My vg64 did that too. Supco will recalibrate it for $40
    May 2009
    Cumming, GA
    The Blu Vac will change the way you perform a vacuum.
    Athens, Ohio
    BluVac is awesome! I should get another one so the installation crew doesn't have to borrow mine.
    In a boiler room
    I had a micron gauge like that too once. Pulled every system down to 100 microns in minutes!
    Worry is a really gross misuse of one's imagination. -- PHM
    Jun 2009
    South Carolina
    Threw a old one away the other day. You turn it on and in less than a min open to atm it would read 50 microns. Everybody wanted to use it to pull vacuums
    Atlanta GA area
    Hmmm... Wonder if there is a way to calibrate one's vacuum gauge... other than send it in and pay?
    Might be a good idea to check every so often.
    Ga-HVAC-tech
    Beware the Dunning-Kruger effect
