    Apr 2013
    Commercial Kitchen Extraction System installation advice
    Hello all,
    I'm new on here and about to start installing my first...and hopefully only extraction system for my new commercial kitchen. I think I'm going to need a bit of help and advice if possible as I can't afford to pay someone to install the equipment. If this is the wrong forum for this then please remove and I understand.
    I yesterday had my equipment delivered and I'm now at the head scratching stage, before long I won't have a head to scratch!
    Basically, this is what I have had delivered and need to install
    2000mm canopy
    1 x IL spigot
    1 x Spiral Duct x 3000mm
    1 x Inline cased Axial Fan
    1 x Pair Motor Flanges
    1 x Speed Controller 6amp
    1 x Top Cowl
    1 x Pair Split Ring Bracket
    Right...where do I start! The ducting is to be installed vertically and coming straight out the top of the canopy, through a pitched roof.
    http://www.ckdirect.co.uk/product_im...rough_roof.gif
    I understand I need to install the fan in the ducting with the motor flanges. Once the flanges are installed on each end of the fan I'm guessing I need to either rivet or use self drilling screws to connect this to the ducting. I'm assuming I will also need to use silicon sealant on these fittings too.
    As the ducting will be coming out of the pitched roof what would be the best way to acheive this? I'm thinking of going direct from the canopy and through the roof and ensuring the appropriate flashing and waterproofing is catered for by a roofer where the tiles have been removed. Is there alternative way that this can be done?
    I hope someone can help and point me in the right direction of where to start!!
    Karl
    Feb 2007
    Fremont, Indiana
    But you're going to use a "professional" roofer???????
    Not a diy site!
    sent from my Samsung Galaxy Note
    Member of the "Work Exchange Program"
    "Will work for knowledge"
    "Everyone is a genius. But if you judge a fish on its ability to climb a tree, it will live its whole life believing that it is stupid"
    A Einstein
    Apr 2013
    Moderator: Please delete thread if not suitable forum but posted in here as forum title didn't specify NO DIY as per other forum subjects.
    Oct 2011
    Chicagoland Area
    May I suggest starting at the beginning. If you start in the middle or the end you will finish the installation quicker but will most likely have extra parts
