Page 3 of 5 FirstFirst 12345 LastLast
Results 27 to 39 of 54
  1. #27
    Salt Lake City/Tooele
    My disclaimer: I have found that these hoses and fittings are working. How long they work is still up in the air. You may have a different experience depending on the quality of the crimping and the hardware you choose to use.
    I am simply showing what I found to work....so far.
  2. #28
    SW Ohio
    Thanks for the link. Finally found the right guy at the right shop. going to make up a 1/2" x 6' of the PTFE stainless braid out the door for $37. Just looking for dedicated vacuum hoses now. For that price its definitly worth a try.
  3. #29
    Jul 2009
    Kansas
    http://www.imperialsupplies.com/grp513.shtml
    http://www.imperialsupplies.com/item/0936130
    If only we could find the 1/4", 3/8", 1/2" Crimp on Fittings for our systems.... There's gotta be a company that manufactures them cause there's tons of different brand hoses out there with pretty much the same fittings.
  4. #30
    Jan 2011
    Ottawa, Canada
    Anybody ever check out this site:
    http://www.greenlinehose.com/pulsar.htm
    They have a catalog on that site with crimp fittings... I dont know all the requirements for a good hose.
    Sent from my GSIII on Tapatalk
  5. #31
    SW Ohio
    Just to clarify, the hoses I'm putting together are NOT the same as slctech posted. The hose is rated the same and the fittings are brass. I'll be adapting the ends as he did. Weatherhead/Eaton is what the local guy can put together reasonably. the fittings on our AC/Refrig hoses from the factory must be proprietary. Varieties of crimp dies and the tools to make them are exhausting and costly. I doubt my usage will come close the extent of slctech's. Time will tell
  6. #32
    Quote Originally Posted by greg58 View Post
    Post pics and let me know how they work out.
  7. #33
    Aug 2001
    Mechanicsville, Virginia
    SW Ohio
    I'll definetly get some pics up. ASAP I was just glad that you renewed the drive to seek again. Got pretty burnt out on the first searches locally. Automakers split town and whats left leaves alot to be desired. I used to to have option of at least 3 places to get anything I needed. But hey, back then it was all cheaper and there wasn't much difference in price.
  9. #35
    Oct 2012
    Where we mow our own grass
    slctech, I hope you don't mind, but I liked the look of your setup, so I copied it and made my own out of stuff I found locally. I used it a few times Thursday and Friday and so far its working pretty good.
Size:  57.0 KBName:  DSCF0875.jpg
Size:  67.7 KBName:  DSCF0876.jpg
Size:  26.9 KBName:  DSCF0877.jpg
Size:  54.0 KBName:  DSCF0878.jpg
  10. #36
    Wow...pretty damn cool. I like how you did your with the ability to take the tree off. Mine is currently permanent.
    I have had no problems yet with the hoses. I had to get away from the YJ ball valves and go to solid YJ fittings. I formed a leak in the ball valve. Other than that no issues vacuuming. Braided lines are a bit grumpy to move around, but the money saved makes up for it.
    I am sure you have realized that we have all been duped by Y/J, JB, Imperial, CPS, and others about having to purchase their extremely over-priced hoses. NO MORE for me.
  11. #37
    Nice garage...ash tray looks a lot like mine...LOL. I need to dump mine soon.
  12. #38
    Oct 2012
    Quote Originally Posted by slctech View Post
    I liked how your pump was with the permanent tee. I wanted to do that with mine, but the handle is so close there wasn't room. Fortunately I found that tree that fits right on top. Robinair sells the tree as an accessory for the pump, it's 1/4" pipe thread on top so possibilities are endless, you can put whatever fittings you want.
    I really like the stainless hoses, I had a couple of the big 1/2" x 6' appion hoses, they where so big and cumbersome, the stainless hoses are more flexible than those for sure.
    Thanks for the idea, I'm really liking the stainless hoses so far.
  13. #39
    On the YJ 6cfm SuperEvac pumps, you can drain the oil, remove the front casing. The handle comes off with that. Attach your goodies to the vac port, and then reattach the front casing. Make sure you use a bit of Nylog around the O-ring/seal. Or remove the handle all together and make your own. On one pump I attached a large eye-bolt so I can easily hook onto it and pull it up onto roofs with my hook and rope. Also can attach a shoulder strap to it.....just think outside the box...it is fun to reinvent and personalize your tools.
