Results 1 to 10 of 10
    Feb 2007
    Heat pump not cooling or heating well
    I bought a home that is 6 years old. The house isn't cooling or heating as it should. Also the rooms do not heat evenly. Some rooms are noticeable colder than others. I went under the house and noticed that the return line to the heat pump was OFF! I reconnected it and cleaned the outside coil, it had quite a bit of dust and dirt built up. Neither one of these things seemed to help much. Any ideas on what might be the culprit for this poor heating/cooling house.
    With the duct off for who knows how long,the evaporator coil ,and blower likely need cleaning.
    This is the indoor coil,although if it's a package unit,it would be inside the package unit.Really should have a Pro do a clean and check service and see what other problems ,if any you might have.
    PA/DE area
    I would make sure it is running right and start from there!!!!!
    It's NOT the BRAND,it's the company that installs it!!!!!
    Florida
    Quote Originally Posted by 94SupraTT View Post
    You need a service call. There are so many things it could be,too numerous to list. Just don't call the installing contractor if his ductwork has already come off. JMO.
    Reminds me of the squirel in the return air looking up at me.... it was a trailer package unit..... here's a question that you might consider.... remember all refrigeration has to do with exchanging heat..... How close to the return air grill is your dryer vent?.....love those calls in the spring.... condenser coil is so dirty that I need to get out my "tech" tool...... it is a hydronic heat exchanger....... (garden hose)...... wash coil collect .... after all I did have to use my HHE tool
    Pricing Removed
    Feb 2007
    Quote Originally Posted by smokin68 View Post
    I am going to have someone come out Monday. Its xxx for them to diagnose the problem.
    Pricing Removed
    Tell them the return duct was off for some time.
    Pricing Removed
    Feb 2007
    The compressor is bad. The guy said he wouldn't even take my money because he didn't feel like he earned it. So I guess thats a plus.
    Lancaster,Ohio
    If your service man didn't know that he deserved the cheap xxx diag fee, chances are he mis-diagnosed the "bad compressor". He spent money showing up to your house, he carried his tools to the unit and opened it up, he spent time testing the system and compondents, was he under your house too? He put it all back together, put his tools away. How long was he there? All that for xxx and he said "I don't deserve it". You need another service man that is worth his wage!!
    Pricing Removed
    IcyFlame
    Feb 2007
    Quote Originally Posted by icyflame View Post
    If your service man didn't know that he deserved the cheap $55.00 diag fee, chances are he mis-diagnosed the "bad compressor". He spent money showing up to your house, he carried his tools to the unit and opened it up, he spent time testing the system and compondents, was he under your house too? He put it all back together, put his tools away. How long was he there? All that for xxx and he said "I don't deserve it". You need another service man that is worth his wage!!
    Sorry to bring up a old post....
    The guy was right it was the compressor. I paid someone else to come out and they replaced the unit for $x this is after they came to the same diagnosis as the other guy. Perhaps the 1st guy was just showing some Southern Hospitality.
    Pricing Removed
