Thread: Pitco 45C+
    Feb 2007
    Fremont, Indiana
    Pitco 45C+
    I have two Pitco's going off on HL
    Both are acting identical where as thermostat is sticking (burner stays on when stat is satisfied, and when temp is turned down).
    I condemned the t-stats on both, but one of my customers swears new stat was installed previously with same results. I am now second guessing my diagnosis on both (same models, different customers).
    Am I correct in assuming that GV stays open and t-stat opens gas flow?
    Is there a Pitco manual more in depth on the gas train/operation?
    TIA
    Member of the "Work Exchange Program"
    "Will work for knowledge"
    "Everyone is a genius. But if you judge a fish on its ability to climb a tree, it will live its whole life believing that it is stupid"
    A Einstein
    Feb 2007
    Fremont, Indiana
    Scratch that
    Found some info, looks as if t-stat operates gv with pressure.
    I'll troubleshoot a little further. Both seem to only malfunction periodically, hope I can catch it!
    A Einstein
    Oct 2008
    Sounds like a bleed-type combination valve with a GS type tstat.
    As my own special little tool, I once rigged a ball valve with fittings to pipe in where tstat goes to test the combination valve. Been awhile, but I think the tstat closes to stop flow of bleed gas through it and back to the combination valve - thereby shutting off main burners. That allowed me to place scrutiny on the combination valve ONLY. If I shut it off the ball valve and the burners stayed on, then the combination valve is faulty. Sometimes it took awhile and numerous on/off cycles to catch it.
    However, make sure your source & operating gas pressures are good first.
    Feb 2007
    Fremont, Indiana
    Quote Originally Posted by ECtofix View Post
    Good info
    Valve closed should turn burners off within 15 sec
    Would still like to see the breakdown and operation of the gv.
    Btw: I went back to one and verified faulty stat.
    Will check the other one (different location) tomorrow.
    Thanks for sharing the ball valve tool/trick!!!
    sent from my Samsung Galaxy Note
    A Einstein
