Results 14 to 15 of 15
    East of big city prices.
    If oil contamination is a concern just purchase the compressor adapter and drain the oil out of the non affected compressor and use standard cleanup methods and there you go.
    Quote Originally Posted by aaron604 View Post
    I was under the impression that in a tandem or dual compressor circuit that you should replace both because whatever affected the compressor that croaked will effect the remaining one, aka acid from burn out moisture, or whatever and then when that one burns out or dies it will take out the new one down the road.
    it is not a requirement to do both compressors. it is good practice on older systems especially if contaminated. on those digi scrolls, they are known to lock up randomly. some tech folks will tell you to replace the solenoid, some tell you to beat them with a 2x4 block of wood and see if you can break them free. been there and have seen it work.
