Results 1 to 2 of 2
Thread: Trane Absorber
    Trane Absorber
    I will be going to look at a Trane absorber.
    Problem is there is a Primary and then secondary
    is half the size of the primary. Both are "T" into
    same stack. Well when secondary comes on, it
    trips all the time. The abnormal or combustion light
    comes on and the unit locks out. The only way to reset
    is to cycle power on it. The honeywell burner module
    is fine it doesn't lock out, only trane's light.
    Could it be the bigger unit is overpowering the smaller
    units combustion ouput in the stack causing some
    incomplete combustion?
    Will the chemical mixture lock out the unit?
    Dec 2001
    Southern Tier, NY
