Results 1 to 8 of 8
    Jan 2013
    California
    Why'd the pilot go out?
    Bad thermocouple believe it or not.
    Sep 2003
    2 diverters are better than one
    May 2012
    Grand Junction, CO
    Quote Originally Posted by small change View Post
    Doesn't that increase efficiency? Lol
    So Cal, Maui, & Kauai
    Even screwewd the 2 together- that's a quality install.
    Sep 2003
    Something I tell all my Water Heater customer's or even Boiler customers
    You have a relief valve on that heater, I am going to test it to make sure it open correctly
    Sometimes they don't reseat properly so I am letting you know ahead of time that I may or may not have to replace it
    if I can't get the (in this case) the Temperature and Pressure Relief Valve to reseat then I will have to change it.
    If you don't want me to work on your water heater or boiler tell me in advance because I will do that test on all relief valves.
    My Insurance company loves me......
    The reason I mention this is the cobwebs that are on that water heater......Just wondering when the last service was on the water heater?
    Mar 2013
    nh seacoast
    is it just me, or is the relief vale in the anode rod port? and what is suposed to be in that hole in the side?
    Dec 2012
    columbus, OH
    Quote Originally Posted by combustioneer View Post
    That hole is to see if its good and warm.
    In a machine room
    At least that dangerous venting is outdoors...
