Results 14 to 18 of 18
    Jan 2013
    Quote Originally Posted by georgehvac View Post
    I called robinair product support and they couldnt find the inlet size- go figure. Same with aa. I ordered a 1/2" npt 1/2" flare tee off fleabay for 6$ to give a try. If it doesn't fit, no big loss.
    It is. Sorry I could not post earlier but I just got back from celebrating Aunt and Uncle's 40th anniversary.
    I looked it up and you are right..1/2" tapered thread.
    Strange AA could not help you...did you talk to Jeremiah? I have the same pump and he knows that thing inside out and they are an authorized Robinair service center.
    Michigan
    Well its not 1/2" npt. Its to big.
    Jan 2013
    Your 15550 is different than mine than. I have noticed that the older Robbie's like mine specs are a little different
    and the diffs don't show up on the specs sheets.
    For instance, my sight glass has a gasket and threads in...newer models are pressed in. My intake is 1/2" tapered.....Sorry I could not help.
    Michigan
    No worries, I appreciate the help. This is the full reply email that I just received from robinair when trying to get the specs. What a joke!
    "This pump come from China and they do not give us the specs on the fitting that you are asking about, the best thing i would be for you to do is take it to a hardware store and try to match it up that way."
    Mit freundlichen Gren / Best regards
    Bobbi
    Bosch Automotive Aftermarket
    Automotive Service Solutions
    Customer Service (AA-AS)
    28635 Mound Rd
    Warren, MI 48092
    www.bosch.com
    Tel. +1-800-533-6127
    Fax: +1-800-283-8665
    S2.AMER.inquiry@spx.com
    Jan 2013
    Bobbi
    28635 Mound Rd
    Warren, MI 48092
    www.bosch.com
    WTH????? Robinair is owned by Bosch now?
    I just talked to Jeremiah at AA Hydraulic. Yours is a China made pump and there is no uniformity to the parts, every pump coming off the line could be any size intake.
    But Jeremiah said that most are 1/2 coarse Tapered pipe thread.
    Mine was American made and and has a straight thread and an O ring to seal it (yeah, I screwed up).
    I would suggest a coarse thread brass nipple And an adapter from JB or YJ and a tee from them also.
    Jeremiah also said this is the consequences of buying a very inexpensive pump (cheap).
    Try to stick with an American made Robbie. Jeremiah probably has some re-fabed or abandoned Robbies you could pick up cheap. This is my suggestion not his. If you want his number email me (any body).
    Add at gmail to my name.
