Results 1 to 13 of 18
    Michigan
    tee for robinair 15500 vacuum pump
    I have a robinair 15500 that im looking to up size the tee for 1/2" hoses. Any one know what size and thread type fits inside the vacuum pump? I thought it was npt, but might be acme?
    Jan 2013
    800 992 9898 ask for Jeremiah.
    They are AA Hydraulic Dervice. An authorized Roinair servicer.
    I got my tee from them. Was a little pricey but I know I got the right part.
    Jan 2013
    Quote Originally Posted by georgehvac View Post
    Where are U in MI? Im in Macomb.
    Jan 2013
    FYI, if you go Appion hoses on 1/2 " you will only need 3/8" tee. Found that out the hard way. My tee is 1/1x1/2 with 3/8 reducers.
    Hope this helps.
    Michigan
    Hey hvac5646- Im in Livonia enjoying the heat wave. Just checked my yj hoses, the're 1/2" flares.
    Michigan
    I called aa but they were closed. Ill try again wed. Thanks for the help!
    Jan 2013
    good. go for the 1/2" tee in that case.
    Delaware
    I remember going through this. What size thread goes directly into the pump.
    Jan 2013
    Quote Originally Posted by energy star View Post
    Can't remember the name of the thread ...but I know for sure it as tapered and the size was either 3/8 or 1/2.
    Mar 2011
    Nathalia, Victoria, Australia
    Hi George, I have a robinair 15444 VacuMaster & the thread into the vac pump is 7/8"ONO which is Dash 14 = 7/8"UNF &14TPI, parallel thread with O Ring champher in the pump. Cheers - Leigh
    Jan 2013
    Quote Originally Posted by LeighC View Post
    I don't think that is the same as the one the gent is talking about...I would post the intake opening but I have to find my manual.
    I found it on Google.
    Michigan
    I called robinair product support and they couldnt find the inlet size- go figure. Same with aa. I ordered a 1/2" npt 1/2" flare tee off fleabay for 6$ to give a try. If it doesn't fit, no big loss.
    Jan 2013
    It is. Sorry I could not post earlier but I just got back from celebrating Aunt and Uncle's 40th anniversary.
    I looked it up and you are right..1/2" tapered thread.
    Strange AA could not help you...did you talk to Jeremiah? I have the same pump and he knows that thing inside out and they are an authorized Robinair service center.
