Results 1 to 7 of 7
    Apr 2013
    Trane Techview CH530
    I have to replace a dynaview panel that is on a CH530 chiller, the display has degraged from being outside. I installed Techview 14.0 on my laptop. What would the procedures be to transfer the parameters to the new panel?
    Jun 2009
    StL, MO
    I'd suggest having a moderator move this thread to the open Chillers forum.
    UA LU 562
    Aug 2009
    Prattville, Alabama
    Are you sure it's not simply a matter of adjusting the display contrast? I've seen many screens that looked blank due to the contrast having been accidently adjusted by an operator, and then the operator thought the screen had failed. Also, the procedure for replacement is not the same for all models, so a model number would help. Or at least what type chiller it's on. And this would probably be better in the pro chillers forum.
    Mount Airy, MD
    Thread relocated to the Chiller section of the site
    Jun 2010
    U.A. (upper Alabama)
    First I would check what nuclrchiller advised. If not that I would post a model number so we don't steer you in the wrong direction, e.g. having you put ctv software on a cgam chiller. Why didn't you just name your self fart? Did it not meet the minimum requirements?
    The Hot South
    This has been discussed many times over the years on this forum. Use the search function and you'll get the info you need.
    May 2011
    NC Foothills
    Do yourself and your customer a favor and install the metal cover on the Dynaview. Every machine should come with one I think.
