    Apr 2013
    Confused Carrier Chiller 30XA0852 Cooler flow switch failure (I am in RED ALERT)
    CARRIER CHILLER 30XA0852 showing cooler flow switch failure and gets tripped out frequently. Chilled water flow switch is working properly. anyone can help me out, what can be the reason? cooler flow switch is different from chilled water flow switch?
    Apr 2010
    California
    Additional infractions may result in loss of posting privileges.
    Jul 2003
    Orange County N.Y.
    Quote Originally Posted by Abdul shukkoor View Post
    Cooler flow switch failure if it is the thermal-dispersion flow switch showing failure then the board isn't getting a signal back from it. You need to know what the actual pressure drop is across the cooler and be able to monitor it before saying that the switch is bad. Small mice have been known to eat the wires sometimes.
    ...Ron
    Roof Rat
