    Carrier 30HXC Heat Exchanger repairs
    Does anyone know a company that can rebuild a heat exchanger (water cooled condenser) for a Carrier 30HXC096R chiller?
    Dec 2006
    tyler tx
    the condsenor should still be avaible through carrier , unless the price is too high . I looked it up on there site,,, If you need the part number i will need the full model number
    If you really want to have it rebuilt, call Carrier's National service center in Houston. 713-797-8900. or see this link: http://www.carriernsc.com
    They can either get you a price to rebuild the old one, or even price up a new one.
    Tight is tight, Too tight is broke.
    Greensboro, NC
    Heat Exchanger Rebuild
    You should check with Thomas Register on re-tubing companies in your area...if you have a tube style
    They will rebuild with same type tube as mfg.
    Get references
