Results 1 to 11 of 11
Thread: Sc56?
    Apr 2013
    Alabama
    Sc56?
    I've been using a uei meter for a little over a year now ,and it's been a pretty good meter considering what I paid for it.however recently I've found out its just not sensative,accurate, or quick enough for certain jobs. Example on a grounded compressor I've got A 50/50 chance of it giving me a good reading to ground.on a locked up compressor it will never show Lra before the compressor goes out on overload or trips the breaker. I've been looking at fieldpiece sc56 because I like the inrush feature and the dual display,but what are your guys experience with it? Is it quick enough and sensative enough to give me accurate readings in the examples above?
    Any feedback is much appreciated, I just don't want to spend more money and still have the same problems.
    My UEi does better when you select a range manually for LRA auto is too slow and trouble with ohms was always solved with fresh batteries. HTH
    May 2010
    Canada
    The SC56 is a very good meter. Keep in mind that it will not read above 600v ( if that is a problem for you ) .
    The inrush feature has worked flawlessly for me.
    Nov 2011
    East Side
    love mine.....but yeah, the autorange feature will slow any good readings.....even on the 56.
    Nov 2009
    Central Virginia
    Love my sc56. I had a problem with the leads after a week of owning them. I called them directly and they shipped me a new set. I still think I will buy some better quality leads though. I dont think youll be disappointed.
    Sent from my SPH-D710 using Tapatalk 2
    ____________________________________________
    If you don't know what you are doing.... ASK!! There is no such thing as a "Stupid" question.... Maybe.
    NH
    Yep sc56 has been great... It got even better though when I bought some longer better test leads for it.
    Only thing I wish it had was a magnet... And maybe a min max amp recording.
    Oct 2008
    Ohio, USA
    Min max amp would be fantastic.
    Also bought some fluke lead combos for it.
    Nov 2009
    Central Virginia
    Quote Originally Posted by Dchappa21 View Post
    A magnet would be a nice feature! It sux to have a nice Fieldpiece meter and have to buy Fluke leads. Fieldpiece needs to step it up on the leads imo.
    Nov 2011
    East Side
    finally found a downside with my 56 today. had to connect the anamometer head using the leads....and the readings were severely lagging from real time. it took a LONG time for the reading to rise and fall. I could actually stop the prop from spinning and it would take 30-60 seconds for the reading to fall.
    I've never tried to use a head with it before......BUT, that's not why I bought it, so still happy overall.
    Jul 2012
    Cincinnati ohio
    I got just got the fieldpiece sc 56 today to replace my unreliable uei 379. I have to say it is me bad@$$ meter. Very fast, inrush is great and actually feels well made. The only complaint I have is there is not storage spot on the meter for your leads and I got really used to having a magnet on the back of the uei that I wish the sc56 had one.
    Jan 2013
    Boss says FP told him the lead lengths are short to reduce impedance.
    Try comparing you reading with the Fluke leads and the FP leads and see if they are different.
