Results 14 to 20 of 20
Thread: Frigidaire iQ 23 SEER
03-12-2008, 09:31 AM #14
With bigger savings.
Appaerently you haven't checked the specs of the Inverter units.
Remember, what you think has little value, may be of great importance to others.
The 23 SEER could allow a 2* increase in stat set point, saving far more in operating cost then a cheaper unit.
03-12-2008, 03:34 PM #15
- Jun 2007
- The Twilight Zone
- 2,964
I have the spec sheet for the Maytag IQ drive. 13.5 EER for the nominal 3 ton, 13 EER for the nominal 4 ton, 15 EER for the nominal 2 ton. These are solid numbers. I am not impressed with a high SEER number because I understand the calculation - it is geared to low ambient temperatures. In hot Texas summers, EER means everything.
How long do you think it will take the OP to recover the additional $5k (minumum) purchase price of the IQ in electricity savings versus a standard 14 SEER / 12 EER system?
03-12-2008, 07:12 PM #16
If its always so hot in texas that the SEER doesn't count, then not too long.
If you really undestood the calcs, you would work in the field. And not just read articles.
Depends on his combined yearly heating and cooling bill.
The IQ could easly reduce it by 25% or more.
Depending on his area, a $100.00 a month decrease would not be out of line.
As electric rates go up, could be a 4 year pay back, or an 8 year pay back.
03-13-2008, 07:53 AM #17
Banned
- Mar 2006
- Delaware
- 448
According to Nordyne, the guy working on the heat pump version of this was killed in a motorcycle accident, delaying the release of this product considerably. They are talking early 2009 right now.
However, I have a neighbor with one of the 23 SEER air conditioners, and he LOVES it! EXTREMELY quiet, utterly uniform temperature control, VERY dry in the summer, and he's claiming it's cheap as dirt to run. No idea what that last part means quantitatively, but there ya go.
I think the cost is worth it, in so many ways, but they just aren't available yet as heat pumps. Given my experience with inverter mini splits, it's GOTTA be one heck of a lot better than conventional units.
03-13-2008, 08:22 AM #18
What some people fail to understand.
In cooling. With high SEER 2 stage, and modulating systems.
Once you get the humidity down. Say to 45% or lower.
In cooling you can set the stat 2 to 5* higher, and still feel as though it was 70* in your house.(or 72, 74, what ever temp they normally had the stat set to)
There is no rating system to tell you how much you will reduce your energy consumption. Because of higher set point due to better humidity control from these systems.
Corpus Christi Texas: From OD temps of 75 to 85 has 2946 CDD, from 85 to 95 has 1221 CDD.
Dallas Texas: From OD temps of 75 to 85 has 1822 CDD, from 85 to 95 has 1150 CDD.
Even in Texas, its not always 95+* outside.
03-13-2008, 01:52 PM #19
I agree with Special Ed, In many cases the linesets, ductwork & airflow won't support the equipment's BTUR rating & the ultra high SEER ratings.
When we are trying to save the customer's on energy costs, "we need to look at everything," including reducing the heatloss-heatgain, equipment sizing, etc. Long & medium term, what customer investments will reduce energy costs the most with the best payback. To me, that is our responsibility to those that put their trust us.
http://www.udarrell.com/proper_cfm_b...g_systems.html
- DarrellAOP Forum Rules:
Rules for Posting
Rules For Equipment Owners
Equipment Owners Find a Contractor HERE!
udarrell
03-13-2008, 02:12 PM #20
- Jun 2007
- The Twilight Zone
- 2,964
