Results 1 to 13 of 27
    Apr 2013
    Walk in cooler trouble
    Once a week, a call will come in that the cooler temp is at 50 degrees. It is a longer run walk in so add just a touch of refrigerant (404) to keep it from short cycling.
    Everything runs fine for 45 minutes and all of a sudden, suction pressure drops and will not rise. Jump out low pressure switch and let it run for a few seconds, and again pressure does not rise, like it is in pump down.
    Removed the TXV bulb and held it in my hand for a minute, no rise in pressure. The workers were moving the items out of the way when my shift was up, but I'm thinking the TXV maybe clogged or stuck closed as I have gotten this call 2 times, but never enough time to troubleshoot it.
    But I have heard from co workers that the pressure will all of a sudden rise and the system will work normal again. Just not sure if it is the TXV or the Liquid line solenoid that is failing as I never have enough time to access the panel to check out the components.
    Any thoughts?
    Salt Lake City/Tooele
    Temperature drop across the LLS will tell you if that is the culprit. Is the LLS even being energized? Remove solenoid (unwire to prevent it from being energized and destroying it when it is off) and throw a magnetic solenoid tester and see what happens. Could be faulty coil or voltage drop somewhere causing not to be fully energized. Thermostat or defrost on the fritz?
    During that 45 minutes when everything seems to be running fine, what are you getting for SH (at compressor and at evap unit), SC, TD's, etc? This will help distinguish if it SEEMS FINE, or if it IS FINE...big difference.
    Coils all clean in and out?
    Fans all operating properly at proper rpm?
    Oil Logging?
    Single evap or multiple?
    Piping engineered and installed properly with traps, slope, etc?
    Keep touching her off with 404, is there a leak? Or are you possibly over-charging. Being a blend, your glide could be way off. Maybe fix leak, for giggles replace LLS, LLFD, and TXV, thermostat (if old mechanical), new oil, deep vac, and virgin refrigerant...nice system over-haul if cond and evap units are in decent condition.
    Just some thoughts.
    Oct 2011
    Chicagoland Area
    Nobody ever has enough time to diagnose/fix things properly the first time, but they always have time to keep returning to the scene of the crime.
    Jul 2012
    Western KY
    Wonder how many times that touch of 404A has been added to keep it from short cycling?
    Jul 2000
    Guayaquil, EC
    It sounds to me like it could be a moisture problem. At least, I'd eliminate that first.
    Oct 2011
    Chicagoland Area
    Quote Originally Posted by icemeister View Post
    BINGO!!!
    Mar 2009
    Mid-Mo
    Quote Originally Posted by 2sac View Post
    Haha, I've heard this a few times...
    Aug 2009
    Maine
    Found a wire broke inside the insulation on the temp control. One of those now you see it and now you don't.
    Quote Originally Posted by Matango02 View Post
    Any thoughts?
    Feb 2011
    OH
    IF YOU HAVE MOISTURE IT WILL FREEZ AND ICE TAKE TORCH HEAT UP IF IT GOES AWAY YOU HAVE MOISTER IT WILL BREAK LOOS LIKE ICE PLUGG ;
    Apr 2013
    Thanks slctech, I posted this on my Friday night and have not been back to work since then, but I will get with the foreman tomorrow morning to see what was found "if info was shared". But you did bring up a good thought about temp drop across LLS, I would not that've thought of that (if I ever have the time to access that side of the panel).
    Hopefully I will get some sort of resolution tomorrow
    May 2010
    Oxford, UK
    Have seen a couple of solenoids with a faulty coil that is ok when cold but goes open circuit when it warms up, then cools and works again. One was a Danfoss and the other was hot water inlet on a wash system on a milk tank. Both times i noticed it while working on the system next to them which makes me wonder if this is a common failure path for coils, as we tend to only see thing when they have failed bad enough for the customer to notice...
    Though i think favourite would be moisture blocking the txv, any colour change in the sight glass? LP switch out of adjustment on pumpdown and a leak in the evap is a common way for the water to get in as i'm sure you know!
    Apr 2013
    Someone found the cooler was on a timer, huh? For a cooler? Timer? Set at 5am when bakery people are in and out? Oh my, time will tell if that call comes back, thanks for responses
    Everything you are explaining in your original post, just explains the common pumpdown procedure for most refrigerant systems. Liquid Line Solenoid is de-energized and closes, compressor pulls refrigerant back into the receiver until the low pressure switch shuts down compressor. That moment that the techs see the pressure spike and system starts to operate is the moment the liquid line solenoid is being energized and refrigerant is let loose.
    Need to see what is causing the liquid line solenoid to have power disrupted to it when the thermostat is calling for cooling. Again, could be the defrost timer, thermostat, valve solenoid, or as strange as it may be a timer. I am not sure here in this regular member forum your experience, is the timer simply a old style Paragon defrost clock? Never seen an actual timer in series with the system controls.
    More concerned about the extra juice you were pumping into this system. Would definitely go back and verify that you have not over-charged this system.
