Thread: Looks Home Made
    Jun 2007
    Williamsport, PA
    Looks Home Made
    Homemade is not always better. This freezer coil was icing up bad at txv. Getting new distributor and
    sweat txv.
    May 2010
    Oxford, UK
    Had to make one like that to save a local curry restaurants stock. Had a leak i couldn't find at first so put some dye in.... Everything glowed green dye to food colouring!!! Then a month later found capilary snapped of exit of distributor. Made new distributor out of squashed 1/2", just make sure to have it level to even up the flow as best as possible.
    Jun 2009
    DFW, TX
    Several times I have seen a home-made distributor nozzle that was favoring one tube over the others. The first one I saw that had an issue, was on a walk-in-cooler and it was freezing up one circuit of the evaporator, and the other two circuits weren't doing anything. I used a pinch off-tool to restrict the flow in the favored one as a last ditch effort, and it worked! All three circuits starting frosting up evenly. I couldn't believe it, but it has been like that for about a year and no other issues. (But of course, your issue of heavy frost on TXV sounds like a different issue altogether.)
    Jun 2007
    Williamsport, PA
    Distributors are inexpensive and easy to install. Sporlan guy sized it and a txv for me. No reason not to do it right.
    Tallahassee, FL
    Ive made homemade distributors before on smaller heat pumps and acs. Seems to work ok.
    I don't know why that one isn't working with only 2 feeders.
    I have seen distributer tubes like that from factory.
    Saddle Up!
