Results 14 to 26 of 42
    Dec 2008
    Looks good from here! Just one thing though. Maybe it's my computer, I can't see any primer on your PVC piping.
    Jan 2011
    Clear primer.... purple stuff looks like crap.
    Jul 2005
    Southern California
    Line set looks fantastic.
    Knowledge is knowing that a tomato is a fruit. Wisdom is knowing not to put it in a fruit salad.
    Apr 2013
    NJ
    Why do you put the Liquid Line Drier on the in side by the Evap?
    Jan 2011
    Quote Originally Posted by njbiker66 View Post
    So it doesn't turn into a rusted mess outside, or rust thru and leak.
    Why not put it inside? That much closer to the metering device, which you want to "filter" what goes thru it.
    Apr 2013
    NJ
    Makes sense to me. I have never worked on residential units/ smaller split systems. Looks really clean that way. Also I like the idea of the two zones and heat pump with gas back up.
    Jan 2011
    We do a ton of hybrid systems like this. Sell more heat pumps than a/c's
    Sep 2012
    Missouri
    1st class!!
    Saint Joseph, MI
    Hmm, I imagined that LP use
    That right furnace obviously was small. Does the furnace cycle on discharge stat if running on high for that zone? Can't imagine there's a duct system big enough for what that 95% furnace will need to move. Or does the other damper open to bleed air to the main zone?
    Inifnity doesn't use a discharge temp. It knows internally based on equipment what the minimum airflows are in each stage. For heat pump and AC, it also factor in outdoor temperature (system capacity) to determine comfort airflows.
    If it's a 60k furnace, it only needs about 1020 CFM on high stage depending on static pressure. The Modulating 60k furance gets by with 970CFM on high stage and 40% capacity on low stage is just 330CFM. Low stage on a 2 ton heat pump is 300CFM minimum. But it prefers 370-490 depending on outside air temp based on my observations.
    Yes, I'm a very very big Infinity fan... 2 systems in my house and can't wait to add zoning some day to one or even both of them.
    That's one of the coolest downflow 2 zone installs I've ever seen.
    Jan 2011
    Thanks!
  11. Likes HeatenCoolair liked this post
  12. #24
    Feb 2013
    Impressive!
  13. #25
    Caledonia WI
    WOW, now that is truly a Masterpiece!
  14. #26
    Oct 2013
    Do you use ratchet benders? If so, do you remove the armaflex first? I have only used mine on very short pieces of lineset and just slid the armaflex back on.
