    Jul 2002
    Manual change Y axis in Niagara R2 logs
    Know of a way to manually change Y axis in Niagara R2 logs? It's always been a nuisence but I now have a log that the Y axis is stuck form 0-.2 and the data goes from 0-100.
    Jul 2002
    Update: We found out the 0 to .2 Y axis was being caused because Niagara cannot handle a NaN in the log. The database must be converted to xml and the NaNs removed. Still can't change the Y scale though.
    Feb 2007
    Helena, Montana
    All I see is "decimalPrecision, which determines the decimal format used to display the y-axis (value) scale in LogChart view." Not really seeing anything else. I always thought it was based on the high and low of the log values.
    Don't worry zombies are looking for brains, you're safe...
