Optimal Condensation Temp
Results 1 to 6 of 6
    Dec 2009
    What in your opinion is the optimal temperature for a water cooled system.
    Keep in mind $$$
    Central WA
    I was taught rule of thumb in absence of mfg specs is 100-105 deg F for both refer and a/c.
    Jan 2013
    Jordan
    it's recommanded that the Condinsing temperature = T (water out) + (4-9) F
    Aug 2009
    Prattville, Alabama
    In the larger tonnage applications, chillers are often custom designed and built for that particular job. Refer to that units design specifications. That may require a call to the manufacturer's rep.
    Aug 2009
    Prattville, Alabama
    As far as "optimum", that could depend. If your trying for max efficiency, colder is better, with limitations. More info is needed on what chiller you're talking about. Too cold water can harm some chillers, such as screw chillers. Too cold water can result in other problems with other types.
    Jul 2011
    East coast USA
    Optimal Condensation Temp is what the equipment was designed for any deviations in the extremes will affect efficiency and tonnage
Comfortech Show Promo Image
Comfortech365 Virtual Event
