Results 1 to 8 of 8
    Apr 2013
    Infinity stat and weather problem?
    im reading this site and you guys look so helpful maybe you can help me.i just hooked up my infinity touch thermostat thru my wireless router (not the one with the unit) and is seams to be working great except that when i pull up the weather it does not give me the outside temp. there is just two lines.it gives me the 5 day and i have the right zip code entered. anybody have any idea? thanks john
    May 2009
    Cumming, GA
    My Infinity Touch Control Router Settings
    The settings need to be changed to use the web to get your local weather. I'm pretty sure this needs to be changed in the service/installers settings. Call a professional for this. Adjusting the service/installers settings without training can cause damage to your system.
    Right now, it is trying to sense the OD temp via a temp thermistor @ the condenser. I'm guessing your system doesn't have a thermistor or it is faulty.
    Apr 2013
    Quote Originally Posted by Brent Ridley View Post
    hi brent, thanks for the responce back. the other thermostat i had did not show the od temp so i guess i don't have a thermistor. i got the infinity touch on ebay so the settings on the touch
    is not something i can do?
    Started a new thread.
    Apr 2013
    hi Brent, one more question for ya.what version software is the lastest for the infinity touch and can it be downloaded somewhere? thanks john
    May 2009
    Cumming, GA
    Quote Originally Posted by njjohn65 View Post
    Version 7 is current.
    Version 8 will be out on May 6th.
    You can update the controller yourself if you're little bit tech savvy. There a specific link you need to download it. I don't have it at the moment. I will try to look it up.
    Apr 2013
    if you can find that link Brent that would be great. thanks for all you help! john
    Apr 2011
    SE Washington
    just curios, what heat pump and air handler is this being used with?
