Thread: alarm notifier
    alarm notifier
    I would like to be notified on off hours if one of my boilers or AC units shut down. What do I need for this? No real DDC in building mostly timers. No guards or night or evening workers.
    Feb 2007
    tampa fl
    Thumbs up stats
    Quote Originally Posted by coachmoon View Post
    Add radio shack tele dialer with 2 codes (boiler and chiller) and stats set to normal
    cost less than 200 $
    Fort Worth, TX
    I can vouch for Sensaphone. We had one at my last gig that monitored a blood freezer. If the temp went up or the power went off (the Sensaphone can still dial on battery power through an analog phone line) it would start calling the blood lab staff one by one until somebody answered.
    Building Physics Rule #2:
    Building Physics Rule #3:
    Dec 2006
    Middle Tennessee
    Quote Originally Posted by shophound View Post
    yupper them plasma coolers store many millions of dollars worth
    of blood (high antibody blood), temp needs to be -20 celsius
    you must also have plenty of redundant systems for when you have
    break downs, i got called out at christmas on 1 of those
    damn hp80 systems, had to fix a leak at the evaporator, the forklift can only
    stay in for 20 minutes at a time or it will freeze the hydralics, it is amazing
    the way things react in the cold environment.
    Dec 2003
    Northern VA
    Telephone line... give me some time.
    If your building has a data room with a monitor (such as Liebert Universal Monitor) there may be a spare set of contacts you can use as well.
    "Iron sharpeneth iron..."
