Results 14 to 26 of 27
    Jan 2013
    Quote Originally Posted by Joehvac25 View Post
    What I find odd is this "breakfast table" thing you keep talking about! I wish I had a good one every morning.
    Why? Don't you Yuppers have kitchen tables?
    Atlanta GA area
    In 'down home America' the 'dinner table' is where families (primary and extended) communicate. Truly a lost art in modern society.
    GA-HVAC-Tech
    May 2012
    Upper Michigan
    Quote Originally Posted by ga-hvac-tech View Post
    Sadly yes and like I said I'm no exception. I'm the only one awake in the morning but I wouldn't object to my wife cooking me eggs and bacon!
    Jan 2013
    So why the "odd" comment?
    In our culture it is not uncommon to have several generations under one roof.
    There are guys on this forum who are the same nationality as my family and know exactly what I mean.. And the Uncle is the Patriarch of our family and the Boss of the business.
    Jan 2013
    Quote Originally Posted by jim bergmann View Post
    Nylog is an oil based product. It will not hurt the transducers.
    Thanks. I thought I had read a post by Mr. Lockhart that said to be weary of using sealers on the intakes.
    I know the Nylog is miscible in oil but I was also concerned about oil floc point while going refer work.
    Jan 2013
    Thumbs up
    could not agree more.
    Jan 2013
    Quote Originally Posted by chuckcrj View Post
    Transducers are protected with stainless steel diaphragms if I remember right, I don't think you could foul them up with anything. I would just use the Nylog.
    Would not a coating of oil retard the signal from the transducer? In essence "insulate" the transducer surface from transmitting a "clean" signal?
    Jan 2013
    This.
    Unless you choose to use an excess of hardening sealant, you aren't going to damage those transducers.
    Even then, the transducer won't be damaged, just rendered useless by an excess of goop.
    I put a bit of teflon on the threads for the fixed portion of the adapter set I had to make, but the swivel fitting is dry. Maybe a bit of oil from use...
    Thanks JP. What is the best remedy if this happens...how would you clean it? It looks easy enough to disassemble the transducer assembly and stick a Q-tip inside...or must there be certain precautions observed?
    Quote Originally Posted by hvac5646 View Post
    Oil on the stainless steel diaphragm of a pressure transducer won't affect its performance at all.
    In a machine room
    No, it would measure oil pressure just as accurately as vapor pressure.
    Jan 2013
    Thanks.
    I'm off to the salt mines now..lol
    Jan 2013
    Thanks. I must brush up on some things it would appear.
    Prevention....
    I suppose that a gently applied orifice drill bit could remedy the situation, but it could also easily destroy the transducer.
