Results 1 to 13 of 27
    Jan 2013
    MUDVILLE REJOICES TODAY...AK REPALACEMENT ARRIVES!
    Got the exchange at the front door today..
    Uncle was grumbling in his coffee as I brought the the box to the breakfast table.
    Took them out of the box and fired it up with the temp-clamps...works like a charm ..even the T1 and T1 agree in ambient air.
    I put the manifold on and the hook.
    One question ...I hate Teflon tape....
    What refer thread dope is preferable in threading the manifold to the head?
    I am thinking Leak Tite or Leak Lock. F
    Opinions please.
    Mar 2009
    Mid-Mo
    Nylog more than the other stuff. The other stuff will harden and never be able to get it back off.
    SW Ohio
    Definitly Nylog over Leak Lock. Tossed the LL after finding Nylog at johnstones.
    Jan 2013
    Thanks for the suggestions.
    I had considered Nylog my self, but was afraid it might some how leech or weep into transducer intakes.
    SW Ohio
    Quote Originally Posted by hvac5646 View Post
    Valid point. I use it the same as teflon tape, stay back a few threads from the end. So far so good on my 1250's mounted on sherman
    In a machine room
    Transducers are protected with stainless steel diaphragms if I remember right, I don't think you could foul them up with anything. I would just use the Nylog.
    Atlanta GA area
    Agree with Nylog... great stuff!
    It mixes well with most all refrigerant oils... so it will not goop up or clog things.
    GA-HVAC-Tech
    Jan 2005
    Akron
    Nylog is an oil based product. It will not hurt the transducers.
    JLB,
    Jun 2009
    South Carolina
    just got my ak from ya jim. Thanks nylog worked great and cant wait to try them out tomorrow. Thanks for the great prices you have along with excellent service!!
    Apr 2002
    Wilkes-Barre/Scranton, PA
    Hmmm, you work and also live with your Uncle? Sounds a bit odd!
    Jan 2013
    Quote Originally Posted by AirTechMech View Post
    I would normally have a sharp retort for that kind of remark..instead i would ask you instead why it's odd?
    Do you know enough about me and mine to call it "odd"? Or are you just drawing some unjustifiable lurid conclusions?
    May 2012
    Upper Michigan
    What I find odd is this "breakfast table" thing you keep talking about! I wish I had a good one every morning.
    Quote Originally Posted by chuckcrj View Post
    This.
    Unless you choose to use an excess of hardening sealant, you aren't going to damage those transducers.
    Even then, the transducer won't be damaged, just rendered useless by an excess of goop.
    I put a bit of teflon on the threads for the fixed portion of the adapter set I had to make, but the swivel fitting is dry. Maybe a bit of oil from use...
