Results 1 to 13 of 37
    Mar 2013
    My first blown transformer! (I'm so proud)
    Went to jump out a water source heat pump today using R to Y1 (the maintenance guys would of had to start it using their automated system, and they typically don't want to be bothered). It still wouldn't energize so I decided to take the jumper off (with 460 volts still flowing through). One side of my beautiful little magnetic jumper wire (those $10 yellow ones) popped off and instantly stuck to some other metal, apparently grounding the transformer. Sparks and smoke...kicked the breaker....so I ended up bothering the maintenance guys anyway (didn't know where the breaker box was).
    Hope this makes your day seem a little less worse.
    Feb 2013
    Lamar, SC
    I did better than that yesterday. I got my assignments in the morning and I accidentally went to the billing address instead of the place I was supposed to go (laundromat franchises). I did tune ups on 3 machines and was almost completely done, only thing left was to wash the condensers so I started to do the paperwork before my hands got wet and discovered my mistake then. I called the office and told dispatch what happened, and she said they didn't have tune ups done at that location. No wonder the indoor coils were so dirty. I went ahead and finished, had the attendant sign the paperwork, and drove 30 minutes to the right location, 3 hours behind schedule LOL.
    "If you've eliminated all other possibilities whatever remains must be the truth."
    Jul 2011
    Lehigh Valley, PA
    Austin, you need electrical training. You must be very careful jumping out any voltage above 24v if you do it at all. Never take high voltage for granted especially any high amperage circuits. What kind of circuit flows 480v thru R & Y1 connections. Sounds like you shorted the primary side. What was the secondary voltage?
    what? no pictures?
    the worst thing that i heard happen was a 7.5 ton compressor changeout at a mall. the guys i used to work with changed the compressor in a unit that was working and was for the space next door to the failed unit!
    Mar 2013
    Quote Originally Posted by Capz View Post
    460 volt primary, 24 volt secondary, result of mistake was an open primary coil. I do have electrical training, but I got in a big hurry and attempted to do something which I have not been trained to do yet. Won't do that again.
    May 2011
    Western, KY
    Quote Originally Posted by jayguy View Post
    what? no pictures?
    I worked with a guy who was a good tech but I got a call to help him on a compressor changeout, got there and he was taking out a compressor on a RTU he had installed the day before but on the wrong unit that didn't have any problems, he was pretty upset about it but the paperwork was not clear and he didn't diagnose the original unit.
    Then there was my last company where a resi pack unit was pulled out and rolled off to the side until the HO came out and freaked because it was the wrong unit, they had another pack around the corner. They were told the wrong unit on that one.
    May 2012
    Upper Michigan
    Quote Originally Posted by jmsmars1 View Post
    Been there lol. I was trying to find a house in a small town and the only house without a number on it was the one I thought could be it. Door was unlocked, they had an oil furnace and that's what I was looking for. I had it pulled apart and the nozzle size didn't match what was on my sheet (we keep track of that stuff), so I did some snooping and realized it was the wrong house lol.
    Dec 2008
    Ontario Canada
    Magnetic jumper?
    Jun 2009
    South Carolina
    We had one last summer.
    compressor went out and we got an okay to install a new condenser . These guys were not thinking. We had three guys go over to change the CU out because it was 12' plus in the air so we had to use our Genie lift and such. They pumped it down and threw the unit off the stand to the ground below. Come to find out they tore the wrong unit out. They tidied up the panels back out and put it back on the stand and installed the new condenser in place of the bad. Somehow the condenser that got a nice drop is still running today. The invoice had the model and serial number of bad system but their explanation was the new condenser was so big so we changed out the bigger unit WTF. 13 seers are bigger than 10 seer. Uhh enough of my rant it was a very stressful day
    o yeah and one time a tech installed a compressor at the wrong house so he had to put the old back in their unit and go install the new one next door. He didnt check the address on the house with the ticket
    Jul 2011
    Lehigh Valley, PA
    Quote Originally Posted by HVAC_Austin View Post
    You tend to remember mistakes made when it involves a big **S spark and tripped breaker.
    And there is no trainer or training which will show you how to jump 460v connections. Not in my book or experiences anyway. Take care.
    May 2009
    Cumming, GA
    Quote Originally Posted by Joehvac25 View Post
    This happened once when I was helper (many years ago). We were dispatched to a specific address; the number was something like 234...we went to 324 or something like that. It was a service call and the unit was broken! Frozen up. They let us in, we fixed, and left....billed the original customer. We only figured out our mistake when the right homeowner called wanting to know where we were!
    May 2012
    Upper Michigan
    Magnetic jumper wires just seem like an accident waiting to happen, they are made to stick to metal and we know how that turns out.
    Mar 2013
    Quote Originally Posted by LKJoel View Post
    Magnetic jumper?
    They sounded like a good idea, but like Joehvac25 says they apparently can cause problems if you're not careful. Will think very carefully before using them again. Picture below.
