Results 1 to 9 of 9
    Lake Havasu AZ.
    Viconics thermostat
    Is there anyway to override or hack the thermostat? It is always to hot in my room and I'm not able to change the temperature and sometimes the heat gets stuck on and gets over 80 degrees and I have to turn the breaker off, it's alittle split system from what I can tell.
    Lake Havasu AZ.
    I basically just wanna exit "sys mode heat"
    Atlanta,GA.
    part of a building control system? a little more info please
    Lake Havasu AZ.
    Yes, I assume someone is controlling the temp remotely but just does a poor job
    Jun 2006
    New Jersey
    There is a very easy way to get rid of BMS control.......but I don't think who ever has control would be ok with it.
    Lake Havasu AZ.
    Quote Originally Posted by ascj View Post
    I would really appreciate if you told me its almost 90 degrees
    Aug 2009
    Prattville, Alabama
    Are you sure it's overheating, and not undercooling? The purpose of BMS systems is to save money. If it is overheating, it is wasting money. This could be an equipment issue that needs addressing. Or BMS has an issue. Have someone look into it.
    Lake Havasu AZ.
    It won't exit sys mode heat, I wanna go into cooling mode
    You need to check with the building engineer.
