Page 3 of 3 FirstFirst 123
Results 27 to 35 of 35
Thread: Rusted bolts
  1. #27
    May 2010
    Oxford, UK
    Would a ball joint splitter be any use? Not sure if i'm picturing it correctly.
  2. #28
    up in the hizzy
    Quote Originally Posted by GT Jets View Post
    Don't forget to sprinkle some talc powder on the new stainless bolts, otherwise they could get galled up on the installation process....
    Been dealing with stainless steel fasteners my entire adult life, was a marine/boat mechanic before making things cooler....
    What brand of baby powder do you prefer? do you think fine flour would do the job too? how bout stainless grade vaseline? I'm very worry about galling up stainless bolts
  3. #29
    Aug 2009
    Maine
    I think you mean a ball joint press. That should work, or maybe a pitman arm puller. Trouble is these aren't things that are usually carried in a service truck.
    Quote Originally Posted by monkeyspanners View Post
  4. #30
    May 2010
    Oxford, UK
    Quote Originally Posted by lytning View Post
    Its a sort of scissor action tool, two fingers to go either side on top and one to push on the thread below, its actioned by a setscrew at the other end.
    I don't carry one on the truck either but think the guys been working on it a week so he could have picked one up in the time!
  5. #31
    Aug 2009
    Maine
    I think you may be right.
  6. #32
    Mar 2010
    Morgan Hill Ca.
    Quote Originally Posted by valdelocc View Post
    Name:  Not sure if serious.jpg
  7. #33
    Apr 2010
    NYC
    Quote Originally Posted by chesehd View Post
    It is going to sound crazy but after soaking with WD-40/PB Blaster/Liquid Wrench try to tighten the heads just a little bit to break them loose. You can also spend about 2-3 minutes tapping each bolt with a hammer before turning them. I know tightening is the exact opposite of your objective but after soaking, then tapping, it frequently works.
    If all that fails there is always the torch...
    Good Luck!
    Ken
    I put up with the deletes because of this. I never once tried that.
    It does make sense. Ill plug the orange can K
    Customer is alWays opposite of Left
  8. #34
    Quote Originally Posted by zartangreen View Post
    I try to tighten almost everything before I loosen it. Works every time and you will rarely break bolts when you get in the habit of doing this. Also a big fan of WD-40. Don't care for PB or Aero-Kroil or any of these other home-made concoctions. I do like a product made by CRC called screw-loose. Seems to work pretty good.
  9. #35
    too bad you cant get a sawzall in there ....
