Results 14 to 21 of 21
    Apr 2010
    San Diego, CA
    While that would be considered a receiver...technically, it's not exactly the type we were referring to.
    Perhaps jimp is just having a bit of fun.
    Exactly.
    Westmont IL
    Thanks for the info guys. This has already been hacked together and getting it working was most important. Just putting off the replacement for a bit.
    Apr 2003
    Maple Grove, MN
    You could always completely fill up the receiver and make it act like a critically charged system again, or probably better yet, just remove the receiver.
    Central Florida
    One of the machines is a Virtis Ultra LE 25, has daul compressors with receivers and caps.
    Filling the reciever will make for interesting start up. Remove reciever and install cap tube drier or some other access for highside. In the 80's I serviced an ice bank bulk tank with captubes and recievers. The recievers were due to length of evap. tubes. Thus large volume of refrigerant required to flood
    Apr 2010
    San Diego, CA
    Quote Originally Posted by jimp View Post
    Cooling multiple loops (shelf/condenser/neg. shelf) at different times during the run, sometimes more than one loop. Varying loads - a small receiver helps reduce the time spent pushing vapor through the cap tubes... This is what I've always assumed.
    Of course, anyone doing Ultra Low temp long enough knows that some of the normal rules get ignored.
    Jul 2000
    Guayaquil, EC
    Quote Originally Posted by ammoniadog View Post
    Quote Originally Posted by ETC1 View Post
    Filling the receiver will make for interesting start up.
    Since the refrigerant in a cap tube system will tend to migrate to the coldest spot...,ie the evaporator...adding a receiver full of liquid to the mix can cause some very severe floodback on startup.
    Most of the units where I've found them receivers installed with cap tubes had 1-2 year old compressors with bad valves. I'm surprised those little guys lasted as long as they did.
    Central Florida
    The shelf compressor only cools the shelf, it has two caps. One cap is for cooling, one is for when the recipe calls for no cooling. The condenser compressor cools the condenser of course, unless the switch is off. If the shelf is on and the condenser switch is off the condenser compressor still runs and supports the shelf cooling.
