Results 1 to 13 of 29
    Jan 2013
    Now that I have my AKs now what....
    ..what do I do for en evac manifold?
    Heard about Sherman but don't know what is so superior to it compared to others.
    A little guidance please.
    Atlanta GA area
    DC products will fit directly on a Titan 2 manifold from YJ. Not the best manifold out there... however it works. Personally I can tolerate the valves in return for not having the offsets between the head and manifold.
    I like to chide Doug about making a set of DC's the standard size... he never replies... <grin>
    GA-HVAC-Tech
    Jan 2013
    I have a YJ Brute II for 410 a...was thinking about that, but i am not sure about the valves.
    Lockart?
    He's probably too busy throwing a hissy over your righteous inquiry.
    Jun 2002
    south jersey
    You did not buy them with the manifold? Was it much cheaper without?
    Jan 2013
    Quote Originally Posted by jnsrose View Post
    Got them with the manifold....about 30 less with out .
    May 2009
    Cumming, GA
    The DC manifold is great. It is one of my favorite features.
    They're equipped with quarter turn ball valves. I have become spoiled....I don't like using a standard manifold anymore.
    Jan 2013
    Quote Originally Posted by Brent Ridley View Post
    I bought them with vac rated hoses...I want an evac manifold for the times I choose to go that way.
    A 3/8" x 1/4" hose on the center port of a two way pulls practically as fast as a 4 way with 3/8 vac port. If you want to add an extra connection for a refer tank use a CRT on the center port of a Two way and can double as a vac blank off.
    Jan 2013
    Great suggestion Ice. But I really like an evac manifold for service. Been using one since I was fourteen.
    Jan 2013
    Got the clamp temp probes. Don't think I am going for any mods to them.
    Atlanta GA area
    Quote Originally Posted by hvac5646 View Post
    I do mostly residential... and I agree a 4 valver is both easy to use and convenient. Generally I plan my installs and repairs to button up the lineset early and let the pump chug for at least an hour. Lots of time I have gotten down into the 200's... with a rise to well less than 500.
    Believe it or not... the Titan 2 has worked well for 6+ years (I have a set of replacement valves for it... have replaced the high side-red hose-once)... I replace my hoses every spring... a few weeks ago.
    When I use a CRT, I use Appions... they really do hold a vacuum better.
    GA-HVAC-Tech
    Jan 2013
    I'v been using the AVG 2 micron head with an ETW2 trans to monitor vacuum on either my SC 57 or HG 3 as I do the metal work and wiring in the basement.
    I was always a fuss butt about the micron level and never leave the CU til it was done. Took a while to build up the confidence to stay away from the CU and watch the evacuation remotely.
    I
    Atlanta GA area
    Generally, I just get the lines buttoned up and let the pump run. If it runs too much... well it is not my electricity... <grin>
    I use my trusty YJ 69075 micron gauge... been using it for 6+ years. Had to replace the sensor once... they do not like being hit with 100#+ pressure when you open the service valves (tired after a long day).
    Good tools and good service practices... means good work and happy customers... which means referrals!!!
    GA-HVAC-Tech
