+ Reply to Thread
Results 1 to 18 of 18
Thread: Slushing Hoshi
    On a bull named Foo Manchu
    Slushing Hoshi
    I had a slushing Hos the other dayi. First one for me. Anybody seen this before?
    Jul 2000
    Guayaquil, EC
    I don't recall ever seeing a Hoshizaki cuber slush, but I read something about an anti-slush control dip switch setting on the board...but I think that was on remote condensing unit models.
    What model was it?
    Pittsburgh
    I have not seen this either on a Hosi, Doesn't the pump stop for a certain amount of time to prevent this ?
    Oct 2009
    Raleigh, NC
    No, Hoshi pumps don't stop. They just don't slush due to their evap design. I have never seen one slush more than just a tiny bit floating on the sump water.
    Jul 2010
    So-Cal
    I think it might have some thing to do with the incoming water being to cold.
    Oct 2009
    Raleigh, NC
    I have seen incoming water temps just under 40 degrees not cause any issues with a Hoshi.
    Oct 2011
    Chicagoland Area
    Never on a Hoshi
    Why is it that those who complain the most contribute the least?
    MONEY CAN'T BUY HAPPINESS. POVERTY CAN'T BUY ANYTHING
    LEHIGH VALLEY, PA
    i have seen manitowocs slush but never a hoshi , warm water entering meeting cold water forms a light slush on the manis , there tec said lower the water level ( adjustable float valve type)
    Newnan Ga,
    A slushing hoshi were it is uncommon you will find debris in the water distribution tubes for the inner evap (hoshi has water that collects cold by running water between evap panels as well as over icemaking side) pull all the upper plastic dist tubes out and clean it will solv your problem
    Newnan Ga,
    Also hoshi has a water inlet temp probe that will tell if hot water is present it will send off 4 beeps from the board
    Oct 2009
    Raleigh, NC
    Grayline, there should be no water running between plates during freeze ever. Also, there is no inlet water temp probe, and I think a 4 beep error is shorted float.
    Sent from my ADR6350 using Tapatalk 2
    Newnan Ga,
    Yes your right forgot 4 beeps= shorted k4 but if you pull your dist tubes out youll see there in a tee shape with holes in the bottom which fits between the evap plates to circulate and get all the cold water off the inner tubes
    Oct 2009
    Raleigh, NC
    The inlet water distributor most certainly flows water between the plates. This functions to distribute heat during harvest. There should be no flow between plates during freeze ever.
  14. #14
    Feb 2011
    OH
    THE ONLY HOSHI IVE EVER SEEN SLUSHI IS DCM WHEN THEY 1ST CAME OUT HAD TO PUT TIMER ON THEM . ,
  15. #15
    What model was it?
    It was a traditional remote The M# escapes me ATM
    If I get a min. I'll post a video clip.
    My ears heard the pump sputtering and when I looked the whole sump was slushed .......
  16. #16
    Quote Originally Posted by david chamberla View Post
    Was this wet ice? I can't picture a slushing on this style.
  17. #17
    Haven't heard back. Must have been a one time deal.
    http://www.youtube.com/watch?v=-YpDn...KBcTLQ&index=1
  18. #18
    Oct 2011
    Chicagoland Area
    I spotted the problem right away. There is no mold/mildew boogers on the unit.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
