    Question What color should liquid propane (LP) flame be for a boiler?
    I have a boiler furnace that is fueled by LP.
    What color should the flame be that burns to heat the tank?
    Thank you.
    LP flame
    Your flame color should be blue, if it is burning yellowish it will soot up your heat exchanger. A Yellow flame is caused by incorrect fuel and air mixture, either starving for air or to much fuel.
    Thank you roxosix.
    Mine is blue.
    I was just trying to eliminate reasons why I am getting lower efficiency out of my boiler this winter.
    It's not the fuel/air mixture.
    manitowoc wisconsin
    Honestly the color of the flame does not mean a pinch of sh*t without knowing the type of burner you have.An old monoport sunflower burner would be producing carbon monoxide through the roof with a blue flame.The only way to tell what a flame is doing is to test it with a combustion analyzer.
    Take your time & do it right!
    Jun 2001
    Louisville, KY
    Quote Originally Posted by markwolf View Post
    Yep.
    Jul 2002
    St Paul, Minnesota
    And don't forget to have the gas pressure checked. It should be set to manufacturers specs. Could be overfiring and still be blue.
